M mroz1sty New member Joined Mar 9, 2023 Messages 3 Mar 9, 2023 #1 Hello, I accidentally deleted the scripts ./letsencrypt.sh file, is it possible to download it from somewhere or recover it?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,143 Location www.poralix.com Mar 9, 2023 #2 Hello, You might try and download it using the guide by the link: https://docs.directadmin.com/direct...ting-da.html#manual-update-using-cli-commands it is the "Manual update using CLI commands" section.
M mroz1sty New member Joined Mar 9, 2023 Messages 3 Mar 9, 2023 #3 zEitEr said: Hello, You might try and download it using the guide by the link: https://docs.directadmin.com/direct...ting-da.html#manual-update-using-cli-commands it is the "Manual update using CLI commands" section. Click to expand... Thanks, it's working.
