Automatically Remove Emails After X Amount of Days
bobsthename
NZ
I was just wondering if it is possible to automatically remove emails from one imap email account after a certain amount of days/weeks/months?
set a cron task (modify it first to meet you needs):
find /home/userbob/imap/domain.com/info/Maildir/cur -mtime +30 -type f -exec rm -f {} +
before to delete you can run this to list emails:
find /home/userbob/imap/domain.com/info/Maildir/cur -mtime +30 -type f -exec ls -la {} +
to remove emails older than 30 days from inbox of [email protected] of user userbob
I tried this, and I can see with du at commandline that the mail folders on disk are <20MB, but in the GUI they still show as >50MB after several days. How come?
Good point. But two questions to follow up:
- Which size does DirectAdmin show, compressed or uncompressed?
- The mailbox sizes shown in DirectAdmin are the same as before I ran the purge. Wouldn't that indicate that the purge didn't have any effect?
I also just looked at some individual files in Maildir/new with less and they actually don't look compressed.
Check your folders visually. That's the simplest way to see how it works. I don't know how you executed the command, and whether or not you replaced words marked in bold with your real data. You might double-check it.
For server-wide check you might run:
find /home/*/imap/*/*/Maildir/{cur,new} -mtime +30 -type f -exec ls -la {} +
for printing a list of files of emails older than 30 days in a console. If you see non-empty results then you should really check command you use.
For deleting files server-wide:
find /home/*/imap/*/*/Maildir/{cur,new} -mtime +30 -type f -exec rm -f {} +
