Please help with reverse proxy (custom HTTPD configuration)
marson
Hello
Our client develop an application in NodeJS it is started on port 3001 and he ask me how to publish it on port 80 / 443 so I write something like this in custom httpd configuration on the domain that they want to publish it:
Alias /.well-known "/var/www/html/.well-known"
RewriteEngine On
RewriteCond %{REQUEST_URI} !^/.well-known/(.*)
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
ProxyPass /.well-known !
ProxyPass "/" "http://localhost:3001/"
ProxyPassReverse "/" "http://localhost:3001/"
and he confirmed that the app is working OK, however now he wants to limit access to this app only for certain IP addresses + allow to proxy it internally and here I am totally loss. Is it even doable? I tried put something like this in custom HTTPD configuration
RewriteEngine On
<Location />
Require all denied
Require ip 185.85.85.1
Require ip 185.85.85.2
Require ip 185.85.85.3
Require ip 185.85.85.4
Require ip 127.0.0.1
ProxyPass / http://localhost:3001/
ProxyPassReverse / localhost:3001/
</Location>
IPs are fake for demonstration my concept.
However this code doesn't work I am getting the following message when I tried to save changes:
AH00526: Syntax error on line 121 of /usr/local/directadmin/data/users/admin/httpd.conf:
ProxyPass|ProxyPassMatch can not have a path when defined in a location.
can anyone help me what I am doing wrong or if my understanding is correct?
if you using "nginx_apache" mode
in custom HTTPD configuration GUI page.
try set this 3 token.
|?PROXY_IP=127.0.0.1|
|?PORT_8080=3001|
|?PORT_8081=3001|
No it is pure apache
I think I found the solution for everyone else in the future:
RewriteEngine On
<Location />
Require all denied
</Location>
ProxyPass / http://mydomain.com:3001/
ProxyPassReverse / http://mydomain.com:3001/
Hello again - I thought I solved the problem, however not entirely.
The domain that I am blocking is a backend of the site let's call this domain https://api2.mysite.com and it is accessible from the IPs I specified but it seems it is not working from localhost. What I mean is that on the same server it is a frontend site hosted at https://mysite.com and the frontend needs to connect to https://api2.mysite.com but it doesn't in the frontent I am getting the following error on chrome console:
I tried to modify above code in the custom HTTPD configuration of api2.mysite.com domain to look like this:
RewriteEngine On
<Location />
Require all denied
Require ip 185.111.111.222
Require local
Require host mysite.com
</Location>
ProxyPass / http://api2.mysite.com:3001/
ProxyPassReverse / http://api2.mysite.com:3001/
Where 185.111.111.222 is the external IP of the server (fake ofcourse)
and still not working, can anybody give me a hint?
P.S if I remove the location section entirely all works OK.
did you trying allow your server ips ( Apache Server ). because I don't know how you call from local ( same server ).
if you call from the same server like.
curl https://api2.mysite.com/api/config
it will filter by your server ips not localhost(127.0.0.1)
if you want to call by 127.0.0.1, it should call this way
curl https://api2.mysite.com/api/config --resolve api2.mysite.com:443:127.0.0.1
so apache can filter as 127.0.0.1
Client said that he connect to api.mysite.com to mysite.com by using angular / javascript, I tried to invoke api2.mysite.com by curl locally and it seems to work.
You might need to open outgoing connections to TCP:3001 in a firewall.
I don't want to open 3001 port, I want to use application on reverse proxy on port 443 and don't open port to world. Also it seems not needed because when I deleted <location> setions from the custom httpd it seems to work OK without opening port 3001
Sorry, maybe I'm misunderstanding your issued. because you told
I think, you have problem on same server with hosting. but from last your reply, look like client use to connect via browser javascript that serve directly to their customer ( maybe I don't know about angular). that's why allow IPs doesn't work because it serve directly to customer, not from their backend script.
it seems you are right, when I added my external IP to require IP section in backend's virtualhost the frontend started working, from my IP so my question is - Am I able to force to proxy the backend to frontend by server IP and not my real IP or this should be done inside an app (that work on port 3001)
yes, it don't need at all, it should done in your Web Appplication ( :3001 ). not from Apache.
