Solved Error restoring domain: php1_select and php2_select must be 0-2
aobh
At the moment I am migrating from one server to another. The backup of 1 user is going fine (with 4 domains). However when I try to restore I get the following error:
Domain domain1 Created: Domain Created Successfully
Domain domain2 Created: Domain Created Successfully
Domain domain3 Created: Domain Created Successfully
Domain domain4 Created: Domain Created Successfully
The originating server has php81, php73 and php56
The new server has php81 and php74
I am using php81 on both servers for this user.
What might the problem be?
Originating server has options.conf:
#PHP Settings
php1_release=5.6
php1_mode=php-fpm
php2_release=7.3
php2_mode=php-fpm
php3_release=8.1
php3_mode=php-fpm
php4_release=no
php4_mode=php-fpm
secure_php=yes
php_ini=no
php_timezone=Europe/Amsterdam
php_ini_type=production
x_mail_header=yes
and new server has options.conf
# PHP Settings
php1_release=8.1
php1_mode=php-fpm
php2_release=7.4
php2_mode=php-fpm
php3_release=no
php3_mode=php-fpm
php4_release=no
php4_mode=php-fpm
secure_php=yes
php_ini=no
x_mail_header=yes
Can anybody help me with this? Do I need to provide more information?
Problem just with that on old servers there was 3 versions and on new only 2, so when it try to restore it see that there is no php number3, because it don't fix exact php version in backup - only position in selector. On old server it was #3 on new #1, so after restore just manually switch php for restored domain.
just temporary enable php3_release to php7.3 ( atleast not too old ). after restore success, switch your user website to php1_release and then remove php3_release version, clean all any relate to php7.3
I added a 3rd PHP release and the problem was gone ;-).
Then it's a bug! Needs to be fixed. Suppose this user is going to another hosting provider and must be restored there and this provider only has 2 php versions or maybe even 1?
IMHO there should be a check for this and if no php3 available, restoration should be restored to default php version.
@fln @smtalk
I can confirm this bug is still present.. I can't believe that I cannot import a backup because my local Directadmin installation is not sure about what php to use, and will refuse to restore :rolleyes:
