Sappie
- Dec 2, 2021
Dear DirectAdmin,
After working with DA for several years now (2 servers) I have a strange problem on one server after updating to version 1.646 (7) with integrated custombuild.
Suddenly options.conf does not correspond with the previous settings and current running versions. Looks like it has reset to all default settings. For example: I actually run php1_release=7.4 php1_mode=php-fpm and php2_release=5.6 php2_mode=php-fpm but options.conf shows only release=8.1 now. Also all other settings are set to default now.
So when I update the versions now it installs V8.1 which causes all website offline.
Also another problem is when I set options.conf back to V7.4 I got SSL disabled for all websites after performing a new update. I have openssl version 1.0.2k-fips installed. I have searched everywhere for a possible solution but I can’t find it unfortunately. I hope you can help. When more info is needed pls. let me know.
Thanks in advance!
Thanks in advance!
