with cpanel, i used to be able to navigate in my browser using the following as an example: http://104.152.168.18/~cremeart/contact.php
how do i go about this via Direct Admin?
./build set userdir_access yes
./build rewrite_confs
thank you for the reply. i read through the documentation link you sent and still lost. sorry, im new to this.Hello,
Set:
Code:cd /usr/local/directadmin/custombuild ./build set userdir_access yes ./build rewrite_confs
Check this : https://docs.directadmin.com/webser...able-the-username-method-of-viewing-a-website
root
in SSH console of your server.Thx again for the follow up. Im going to give that a try. Appreciate it.Those commands you should enter as userroot
The same can be achieved in a web-interface of DirectAdmin, navigate/search to CustomBuild in menu for, change the option "userdir_access" to "yes" and re-write webserver configs. I don't use CustomBuild interface, so I don't have exact instructions.
