error domain name already exists on the system even though the user has been deleted and in the file etc/named.conf
vipkongtu
lỗi tên miền đã tồn tại trên hệ thống mặc định mặc dù người dùng đã bị xóa và trong tệp etc/named.conf
Please keep text in English also in your posts.
Check the /etc/virtual/domains and domainowners files if the domain and/or users are still in there.
Also check /usr/local/directadmin/data/users if the username is indeed deleted from there same for the /home directory.
Thank you! I fixed it! but it gives another error that can't assign ip to user
It says a reseller is required.
Check your /usr/local/directadmin/data/users/admin/ips folder if the ip's mentioned are present there.
They should have this rights and owner:
-rw------- 1 diradmin diradmin
It's odd that this happens, maybe you best send in a ticket to fix things, seems like some things are not in order.
