| Warning: | Don't edit LocalSettings.php with document editors like Notepad on Windows 10 Version 1809 or earlier, TextEdit, or other text editors that add byte order marks to files. These break the PHP runtime of your wiki. Instead, use a code editor, e.g. Vim, Notepad++, or Atom. These handle file encodings properly. |
The file must be located in the folder you installed MediaWiki into, on the same level with folders like includes/and skins/ and files like api.php. If this file is
not there, the wiki will not work at all—if the wiki
does work, the file
is there
www.mediawiki.org
