NGINX Unit not visible
k1l0b1t
Belgium
After installing nginx unit, there is no menu option visible for it.
Using alma9 on arm64. Personal Plus licence.
Check if it is allowed by the user/user-package.
By default it is off and thus not visible/accessible.
Gocha!
I don't see an option anywhere though when I modify a user.
Edit: I don't know what I did, but it works now (I guess saving the user did the trick?
Anyways, is there any way to control this on a per-package basis?
Gocha!
I had the exact same issue today after installing the Nginx Unit on my Direct Admin instance as well. Your "fix" fixed it, so, thank you for that. Clearly, this is a bug that needs to be fixed.
@fln found another bug:
when doing the example on https://docs.directadmin.com/webservices/nginx_unit/ for ruby, I keep getting "invalid "script""
On nodeJS and java, perl, I keep getting 503 errors
Python works
Sorry to ask, but:
What did you put in the configuration for the python application here?
What would the module/callable be?
I am assuming the "path" would be the path to the script, and that the routes allow you to access the script from the web, if you have it some place other than the public_html folder?
@k1l0b1t I would really appreciate it if you could help me. I am just stuck at creating the "Route". Would you be able to explain/provide an image of how you did it? Thank you.
i cant see the opction to enable/disable this feature.
Unit works with openlitespeed?
