following partition(s) have exceeded the 80% threshold: 100% - /
rszkutak
Scottsdale, AZ & Clam Gulch, AK
I'm in a bit of a pickle and have no idea what to do here. It seems to me that I don't see any specific clear cut answer here in the forum as to where to look.
Can anyone guide me to how to fix this? It seems like it's causing some issues.
root@ws1:/dev/mapper# df -h
Filesystem Size Used Avail Use% Mounted on
udev 5.9G 0 5.9G 0% /dev
tmpfs 1.2G 1.3M 1.2G 1% /run
/dev/mapper/vg00-lv01 234G 225G 0 100% /
tmpfs 5.9G 4.0K 5.9G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/sda1 456M 276M 146M 66% /boot
tmpfs 1.2G 0 1.2G 0% /run/user/0
Looks clear to me, the / partition is full.
It's not a big disk I see. But there is 234 GB available and 225GB used, which is more than 80% so it says 100% used.
You have free disk space. I'm not sure what your question is.
Thank you for the response and i'd like to say i'm an idiot. I was looking for something that ended up being too easy to fix but i wasn't sure where to look.
it seems one of my users is using updraft on their website and they had it setup to never delete any backups, so i went in there and purged about a year and a half of backups minus the past 14 days. I'm now running a new backup for them so we have a fresh one.
