Cannot set mail limit over 200/day
dorucrisan
Bucharest / Romania
I need to send bulk e-mail to our customers, 1800 messages. I cannot set numbers of e-mails over 200, once I exceed 200, even 201, the frame becomes red and does not allow to change or save. How can I remove the limit temporarily, even using some coding? I need to send those mails on weekly basis.
Nothing, fresh default install.
Ah wait... I've done a fresh install this week and have seen a 200 limit somewhere.... let me check... ahyeah, directadmin.conf probably still....
Check this:
You can set that value to -1 to be unlimited if I'm not mistaken. And restart DA afterwards.
Also:
Take care, if your server, Ip's becomes a bad note. spammer.
Also your hoster could take actions you don't want.
So only send "mass" mails if you know what you are doing or use a external special "mass" mail service.
Also:
Thank you, I know all that, it is not spam, it is sent to customers.
GO TO Administrative settings >>>> Email, you can change the limits there from 200 to any numbers
In the other post you said you put it to -1 and didn't work.
Try using 0 because that would mean unlimited as far as I can see.
