Solved The service 'php-fpm81' on server usda1.plusd.com is currently down
hmaddy
so i rebuilded the php via terminal
Installing PEAR environment: /usr/local/php81/lib/php/
PHP Warning: PHP Startup: Unable to load dynamic library 'clos_ssa.so' (tried: /usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so (/usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so: cannot open shared object file: No such file or directory), /usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so.so (/usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
make[1]: *** [install-pear-installer] Segmentation fault
make: *** [install-pear] Error 2
Please don't doublepost. You already got a topic about this issue.
I told you in the other thread that this is a Cloudlinux problem, ask over at Cloudlinux.
cloudlinux reply.
Already installed php81 on your server.
alt-php81-pgsql-8.1.5-1.el7.x86_64
alt-php81-sqlite3-8.1.5-1.el7.x86_64
alt-php80-mariadb104-8.0.18-1.el7.x86_64
alt-php80-intl-8.0.18-1.el7.x86_64
alt-php80-sourceguardian-12.1.2-1.el7.x86_64
alt-php81-mysql5.6-8.1.5-1.el7.x86_64
alt-php81-ldap-8.1.5-1.el7.x86_64
alt-php80-mysql5.0-8.0.18-1.el7.x86_64
Also, PHP-FPM isn't compatible with the PHP Selector, according to the Cloudlinux OS Compatibility matrix.
It's still a Cloudlinux issue. Direct admin does not support the extension php-ssa as said before.
If php-fpm isn't compatible with the PHP selector and you're uising the php selecter, you shouldn't use php-fpm anyway.
Same issue with Cloudlinux on cPanel:
this package is available in CloudLinux alt-php8 with the name alt-php-ssa.
Have a look at this:
Please next time keep everything in 1 thread:
Getting it on Ubuntu 22.04 lts.
It was a year ago when this was posted.
Maybe you need a seperate topic for it, or do you have exactly the same error about the PEAR environment? If yes please post the error. If not, start a new thread and post the errors you see.
The service 'php-fpm81' on server server-xx-xxx-xx-xx.da.direct is currently down.
Breand new install of directadmin
Maybe you need to be a bit more pleasant.
As you can see from the first post, it's the same error but probably totally different.
Maybe as a new user, you should try and see answers as info and not interpret them directly as unpleasent. I was merely pointing out how things work on a forum. Your issue is clearly different when you look at the first post. Don't only look at titles on forums.
Probably you need to wait longer for everything to install, in any case it's a totally other issue and then on forums, one starts a new thread.
Preventing the topic starter here to get notifications and others wondering why a topic marked "solved" suddenly starts having posts again with another issues.
Still issues? Happy to help you in your own new topic.
