- Aug 30, 2021
@matkra login page customizations still works if server uses Enhanced or other legacy skin as deafault skin (responsible for rendering login page).
When evolution is used as default skin, login page can be customized using built-in login customization functionality. Located at Admin level -> Admin Tools -> Customize Evolution Skin -> Login Page. You can change login images there and also apply custom CSS, which gives you unlimited power to change the login page design.
