Yes. The hostname is the name of the server, it has nothing to do with the domains running on the server. However, it is used by all domains as the sending mailserver if you send mail, it connects by that name to other mailservers. But that is good, that is default.If I change the host name to server.hitopex.com, can I use this same host for the other domains?
That is correct. At least.... it should contain all default records, so also mail and ftp and www and pop at least.When I create a zone only the host name and the ns are generated.
Sorry, I did not know that the message is private when sent directly. I appreciate your help.@BillyS why do you reply to me?
You can host any domain on the server.
And if DA is setup correctly it should have a TXT record with an SPF line too.
If it has that, yes then it's correct. You should -not- need to add other records manually, if you don't see the ones I mentioned then things need fixing.
Not replying to you, just posting what you said because that was the answer - sorry about the mix up.@BillyS why do you reply to me?
Everything via the forum is not private (except conversations), that is no problem at all so don't worry.Sorry, I did not know that the message is private when sent directly. I appreciate your help.
Connecting to 5.75.206.72
220 server-5-75-206-72.da.direct ESMTP Exim 4.96-58-g4e9ed49f8 Thu, 15 Jun 2023 10:26:13 +0000 [191 ms]
EHLO keeper-us-east-1d.mxtoolbox.com
250-server-5-75-206-72.da.direct Hello keeper-us-east-1d.mxtoolbox.com [18.209.86.113]
250-SIZE 52428800
250-8BITMIME
250-PIPELINING
250-PIPECONNECT
250-AUTH PLAIN LOGIN
250-STARTTLS
250 HELP [218 ms]
MAIL FROM:<[email protected]>
250 OK [397 ms]
RCPT TO:<[email protected]>
550 Sender verify failed [239 ms]
LookupServer 2959ms
And you answered you had a CloudVPS with Hetzner.Is it a real Hetzner server, or is this a new Cloud VPS? Because Cloud VPS systems can not send mail the first month.
