Custombuild with deprecated options
Zhenyapan
UA
I have enabled mod_php and mod_ruid2 on old server with a lot of custom modifications so I must keep it.
Can I temporarily disable both them in options.conf to upgrade all other stuff provided with custombuild (exim/nginx/proftpd/mariadb etc.) and then turn ON back?
Will it broke something?
It may still break some configuration if it is ran forcefully, thus I would not recommend doing it.
and if i modify versions - I still can't run build exim due to mod_php and mod_ruid2 enabled?
