Linux system after centOS.
inomi13
Everyone knows that support centOS will expire on July 30, 2024 and I want to prepare to migration my server to another linux. I found information that the best solution is Rocky linux and such Alma Linux. Is someone use which of them? Is exist any issue with DA on these linuxs vs DA on centOS ?
Aready asked several time here , please search before post.
To answer your question it depends what you want bu most RHEL users are migrated to Almalinux , especially because its back upped by Cloudlinux
Please keep in mind that using CentOS Stream is also an option. CentOS Stream 8 and CentOS Stream 9 are fully supported by DirectAdmin.
So you prefer upgrade CentOS 7 to for example CentOS Stream 9 ? Lots of people say that Almalinux is better solution than CentOS Stream 9
I'm very confused because I checked and I have found information that Alma Linux 9 doesn't support PHP 7.4, however lots of plugins in wordpress works only this version PHP. I know that Alma Linux 8 is supporting PHP. 7.4 but active support this release will be end to (01 May 2024 so now Idon't know which Linux should I to choose.
So if I will have Alma Linux 9 and DirectAdmin Version 1.657 I can be able to use PHP in version 7.4 ?
