Redis installation
max9012
Hi to all,
i have e some trouble with Redis installation.
Directadmin on vps with single user and one website.
Steps i do:
- Enable Redis from custombuild plugin save and build
- last two log lines is:
Done redis.
Enabling redis in systemd..
- Reboot server
- Check trought wordpress plugin and nothing seems working
- Login with root user, lunch command "systemctrl status redis" , and > Unit redis.service could not be found
- Check systemd service in /etc/systemd/system/ and found [email protected]
- Lunch command systemctrl list-units | grep redis > nothing found-
So i tryed to reset configuration to base config, without redis:
- Disable redis from custombuild plugin save.
- Login with root user and lunch:
- da build list_removals
- da build remove_items
- da build remove_old_local libiconv
- da build all
- da build restore_old_local libiconv
Remove libiconv because i have trouble compiling exim: "configure: error: iconv does not support errno"
So now i have my base system working. And i tried to enable redis all from command line lunch command
- ./build set redis yes
- ./build redis
- last two lines are same as previuos
Done redis.
Enabling redis in systemd...
but redis not working like previous attempt...
Any suggestion?
Thank you in advance.
I make more test.
I figure out that [email protected] expect username for service.
i execute : systemctrl enable redis@admin
I added service redis but failed error:
redis-server[756]: 756:C 21 Dec 2023 15:05:31.702 # Fatal error, can't open config file '/usr/local/directadmin/data/use...directory
script search for config file in "ExecStart=/usr/local/bin/redis-server --include /usr/local/directadmin/data/users/${USER}/redis.conf"
but i haven't any redis.con on admin folder.
This is a directadmin bug?
Now i added /usr/local/direcadmin/data/users/{username}/redis.conf and now working as expected.
protected-mode yes
tcp-backlog 511
timeout 0
tcp-keepalive 300
daemonize no
loglevel verbose
More info and complete default redis.conf file on https://redis.io/docs/management/config/
Where is settings? i can't see any setting related to redis on user level Da.
toggle via User Package.
I dont know how to enable redis on DA, documentation not so clear.
Steps i do:
./build redis
From docs "All Reseller/User packages and reseller.conf/user.conf files will have redis=OFF by default."
I checked conf. files under /user/local/direcadmin/data/users/admin/reseller.conf and user.conf
and package conf. under /user/local/direcadmin/data/users/admin/packages/my.pkg
no files have redis=OFF, but assume that default value is OFF, so don't chage anything.
From docs: "The Admin account reseller.conf will have redis=ON by default."
My user is Admin, so default value is ON by default. I don't change any config file.
Now go to DA Dashboard and i don't find any palce where i can toggle Redis, but i can see that redis is disabled
See attachements
1° screen access level admin > edit user packages
2° screen access level admin > show all users > admin > reseller > info
3° screen access level admin > show all users > admin > user > account info
4° screen access level admin > show all users > admin > user > modify
Some docs might not sync with current system.
Did you not see enable option in Admin package or in Reseller Pacjage ?
I don't have any "admin package" items in menu, only "manage user packages".
Yes lagacy licensing..........wtf! need to contatc vps provider...
