I have enabled DKIM (per instructions here), generated DKIM keys (
/usr/local/directadmin/scripts/dkim_create.sh %% nodns
, where %%
is pl-vhost-01.businessdomain
and businessdomain
, both were configured manually in DNS to include DKIM records and appropriate selector from the configuration), however only half of the service emails are signed by DKIM:
Return-Path: <[email protected]>
Delivered-To: myname@businessdomainbusinessdomain
Received: from pl-vhost-01.businessdomain (pl-vhost-01.businessdomain [directadmin-ipaddress])
by personaldomain (Postfix) with ESMTPS id 613F416E00EE
for <abuse@businessdomain>; Tue, 2 Jan 2024 14:40:23 +0200 (EET)
Authentication-Results: personaldomain; dmarc=pass (p=reject dis=none) header.from=pl-vhost-01.businessdomain
Authentication-Results: personaldomain; spf=pass smtp.mailfrom=pl-vhost-01.businessdomain
dkim=pass (2048-bit key) header.d=pl-vhost-01.businessdomain [email protected] header.b=ZUTrmjWI;
dkim-atps=neutral
DKIM-Signature: v=1; a=rsa-sha256; q=dns/txt; c=relaxed/relaxed;
d=pl-vhost-01.businessdomain; s=plv01; h=Date:Message-Id:Subject:To:From:
Sender:Reply-To:Cc:MIME-Version:Content-Type:Content-Transfer-Encoding:
Content-ID:Content-Description:Resent-Date:Resent-From:Resent-Sender:
Resent-To:Resent-Cc:Resent-Message-ID:In-Reply-To:References:List-Id:
List-Help:List-Unsubscribe:List-Subscribe:List-Post:List-Owner:List-Archive;
bh=lLAZK2SGgfOzlFpdipqueqReoOSGMV8bTMJYgTxk6QA=; b=ZUTrmjWId/XcOCj0qxGQbukcrG
ENpJbXiPqo/jFoeO/XOpi1i3TIwayxhWRUo/jjeC5jvLWT3d4PbQFUR3IuYel18+nptsmzx5615kp
a5DWnuoz0rBiZAQA2XE/leFZzZ4EkhbMpoNsX8UN9yphpppvGnNHQl1VlZTTB8hbBNGSrxjUHZ6jQ
U2TJfp39hr39nyTWyVGrbyQGxFCDMtSCCZ8I/ffQMk1xiw0StRa77l+c/y2kGqzN4pYcJDtHbUclP
av9uH172oDJDS1+sQbk72fkOGimJvhcMgxvHnz+YF+RhEGHxNDVUycrUo4+DO/EKZFfwKIRxRMhY6
parlhX0w==;
Received: from root by pl-vhost-01.businessdomain with local (Exim 4.97)
(envelope-from <[email protected]>)
id 1rKe4D-000000037y0-2ILU
for abuse@businessdomain;
Tue, 02 Jan 2024 13:40:21 +0100
To: abuse@businessdomain
Subject: lfd on pl-vhost-01.businessdomain: blocked 167.172.235.223 (Unknown)
Message-Id: <[email protected]>
Date: Tue, 02 Jan 2024 13:40:21 +0100
X-DCC-x.dcc-servers-Metrics: flopster; whitelist
Time: Tue Jan 2 13:40:21 2024 +0100
IP: 167.172.235.223 (Unknown)
Failures: 5 (sshd)
Interval: 3600 seconds
Blocked: Temporary Block for 86400 seconds [LF_SSHD]
Log entries:
Jan 2 13:13:20 pl-vhost-01 sshd[745069]: Invalid user app from 167.172.235.223 port 43308
Jan 2 13:20:05 pl-vhost-01 sshd[745201]: Invalid user appuser from 167.172.235.223 port 39056
Jan 2 13:26:50 pl-vhost-01 sshd[745353]: Invalid user bigdata from 167.172.235.223 port 53952
Jan 2 13:33:35 pl-vhost-01 sshd[745481]: Invalid user bot from 167.172.235.223 port 45372
Jan 2 13:40:20 pl-vhost-01 sshd[745602]: Invalid user centos from 167.172.235.223 port 57556
Return-Path: <abuse@businessdomain>
by personaldomain (Postfix) with ESMTPS id C1CBA16E00EE
Authentication-Results: personaldomain; dmarc=pass (p=reject dis=none) header.from=businessdomain
Authentication-Results: personaldomain; spf=pass smtp.mailfrom=businessdomain
(envelope-from <abuse@businessdomain>)
id 1rKe4E-000000037y9-0BA6;
Tue, 02 Jan 2024 13:40:22 +0100
To: abuse@businessdomain,[email protected]
Auto-Submitted: auto-generated
X-XARF: PLAIN
Content-Type: multipart/mixed;
boundary="csf-1704199221"
MIME-Version: 1.0
Subject: abuse report about 167.172.235.223 - 2024-01-02T13:40:21+0100
Date: Tue, 02 Jan 2024 13:40:22 +0100
This is a multi-part message in MIME format.
--csf-1704199221
Content-Transfer-Encoding: 7bit
Content-Type: text/plain; charset=utf-8
The IP address 167.172.235.223 (Unknown) was found attacking sshd on pl-vhost-01.businessdomain 5 times in the last 3600 seconds.
Attached is an X-ARF report (see http://www.xarf.org/specification.html) and the original log report that triggered this block.
Abuse Contact for 167.172.235.223: [[email protected]]
The Abuse Contact of this report was provided by the Abuse Contact DB by abusix.com. abusix.com does not maintain the content of the database. All information which we pass out, derives from the RIR databases and is processed for ease of use. If you want to change or report non working abuse contacts please contact the appropriate RIR. If you have any further question, contact abusix.com directly via email ([email protected]). Information about the Abuse Contact Database can be found here:
https://abusix.com/global-reporting/abuse-contact-db
abusix.com is neither responsible nor liable for the content or accuracy of this message.
--csf-1704199221
Content-Disposition: attachment; filename="report.txt"
Content-Type: text/plain; charset=utf8; name="report.txt";
Reported-From: abuse@businessdomain
Report-ID: [email protected]
Category: abuse
Report-Type: login-attack
Service: sshd
User-Agent: csf v14.20
Date: 2024-01-02T13:40:21+0100
Source: 167.172.235.223
Source-Type: ipv4
Attachment: text/plain
Schema-URL: https://download.configserver.com/abuse_login-attack_0.2.json
--csf-1704199221
Content-Disposition: attachment; filename="logfile.log"
Content-Type: text/plain; charset=utf8; name="logfile.log";
--csf-1704199221--
[root@pl-vhost-01 ~]# ls /etc/virtual/pl-vhost-01.businessdomain/
dkim.private.key dkim.public.key
[root@pl-vhost-01 ~]# ls /etc/virtual/businessdomain/
