Hot fix has repaired resource reporting but my PHP update problem persists.
Support (in my case) now declares below. Any idea what this is all about?
We found the following error in LOG file:
configure:27287: checking for SSL support in libcurl
configure:27292: result: yes
configure:27306: checking for libcurl linked against old openssl
configure:27345: cc -o conftest  -fstack-protector-strong -D_FORTIFY_SOURCE=1 -O1 -fvisibility=hidden   -Wl,-rpath,/usr/lib/x86_64-linux-gnu/mit-krb5 -L/usr/lib/x86_64-linux-gnu/mit-krb5 -lcurl conftest.c -lutil -lrt -lm -ldl  -lsystemd -lxml2 -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -lsqlite3 -lz -lcurl >&5
/usr/bin/ld: error: /lib/x86_64-linux-gnu/libkeyutils.so.1: file too short
collect2: error: ld returned 1 exit status
configure:27345: $? = 1
then we checked that "libkeyutils.so" file and found that your server is hacked, because we see different results:
  root@isp1:~# ls -la /lib/x86_64-linux-gnu/libkeyutils*
  lrwxrwxrwx 1 root root    20 Feb 10  2020 /lib/x86_64-linux-gnu/libkeyutils.so.1 -> libkeyutils.so.1.9
  -rw-r--r-- 1 root root 22448 Feb 10  2020 /lib/x86_64-linux-gnu/libkeyutils.so.1.9
  root@isp1:~#
but:
  root@isp1:~# strace -o /dev/null ls -la /lib/x86_64-linux-gnu/libkeyutils*
  lrwxrwxrwx 1 root root    20 Feb 10  2020 /lib/x86_64-linux-gnu/libkeyutils.so.1 -> libkeyutils.so.1.9.2
  root@isp1:~#
and even more clear: that file is not visible using just "ls" command:
  root@isp1:~# ls -la /lib/x86_64-linux-gnu/libkeyutils.so.1.9.2
  ls: cannot access '/lib/x86_64-linux-gnu/libkeyutils.so.1.9.2': No such file or directory
  root@isp1:~#
but it can be seen, for example using "strace" command:
  root@isp1:~# strace -o /dev/null ls -la /lib/x86_64-linux-gnu/libkeyutils.so.1.9.2
  -rwSr--r-- 1 root root 59808 Feb 10  2020 /lib/x86_64-linux-gnu/libkeyutils.so.1.9.2
  root@isp1:~#
So, you have 2 options:
 - remove that file and continue using the server and have a hope that it was only one malicious file there. After that PHP will be recompiled correctly.
or
 - create new server, install DA there and migrate your DA users to that server.
