DMARC
Pens
I have 4 domains on my server, the DNS is set up in exactly the same way but 3 of them show
TestResult
Status ProblemDMARC Record PublishedNo DMARC Record foundInformation More Info
Status WarningDMARC Policy Not EnabledDMARC Quarantine/Reject policy not enabledInformation More Info
in MXToolbox. com
the 4th (the last domain I added) shows
TestResult
Status OkDMARC Record PublishedDMARC Record found
Status OkDMARC Policy Not EnabledDMARC Quarantine/Reject policy enabled
The setting I have in the DNS records for each account is
_dmarc
3600TXT"v=DMARC1;p=reject"
Is this a matter of updating the DNS records somewhere? if so where?
Can be a couple of things. Do you use your own nameservers or external nameservers?
You're sure on that 1 which does not work you have DMARC1 all in capitals for example? Didn't forget any " in there or something?
Is the domain propagated properly already?
Hard to say just by this. Maybe I can do a bit more if I know the domain name (if required it can also be given via pm).
But need to know first if own or external nameservers are used.
Thanks,
It's an internal nameserver.
I'll PM you, the last time I put a IP address and domain name on here, I had 1,500 brute force attack attempts on them the following day.
Regards
