Solved Error when trying to restore a database from the panel.
exemaco
Hello everyone,I am having a problem, I cannot restore databases from the control panel, however from phpmyadmin it works without problems, the error I get in the panel is "password is missing" .
I was checking the configuration of this guide, and I see that this is all in order: https://docs.directadmin.com/other-hosting-services/mariadb-mysql/troubleshooting.htmlCan anyone tell me what could be happening?
do you mean this option?
If yes, did you provide the correct user and password here?
In Evo skin it looks a bit different, but if I'm correct you have to use the other selection box, like here, and then specify the db-user and db-password.
Hi, yes yes, I was using the option: "Your current login information" excuse my ignorance, entering the credentials manually works. THANKS!
