Solved Server wont boot
ericosman
Weert
Hi all,
I'm setting up a new server, and i think after using the following command:
mkdir /home2
echo "/dev/sdbnvme2n1 /home2 ext4 defaults 1 2" >> /etc/fstab
mount /dev/sdbnvme2n1 /home2
The server doesnt like to boot anymore, now i'm waiting for a KVM console so i can check.
But how would i remove this from the fstab?
That's odd. My nvme devices are just named /dev/sda and /dev/sdb but not /dev/sdbnvme2n1 or something like that.
As for your question, just remove the line:
from /etc/fstab and you should be fine after reboot.
Why did you use 1 2 and not 0 0 or 0 1 or something like that? I've read the first 1 is the dump command which is rarely used anymore.
Maybe if the device is correct the first 1 is wrong, unless you installed dump. Normally this is always always always a 0, for many years already.
The 2 is for the file check. So if the device is correct, you could also try 0 2 at the end to see if it boots. But never use 1 in the dump value.
also fstab always must be finished by new line, and looks like you put your text to last line. Try edit file and add to end new empty line
Well, during start i have this
"a start job is running for dev-sdbnvme2n1.device" (..s / 1min 30)"
Then
Timed out waiting for device dev-sdbnvme2n1.device."
Dependency failed for File system check on /dev/sdbnvme2n1
Dependency failed for /home2
Dependency failed for local File systems
Dependency failed for Mark the need to relabel after reboot.
Now i edit the file /etc/fstab
And put a # at the arrows:
Now during reboot i get "Failed to mount /home2"
very strange dev-address, remove this string, boot normally without it. check correct UUID and mount it by UUID.
you can check UUID with "blkid" command
like on screen
and why mount point cropped? where filesystem and mount options? for last line.
Did you een create a /home2 directory before you started your mount commands?
After /etc/fstab changes in Alma I normally also have to make the final with this command:
systemctl daemon-reload
File /etc/fstab is unwritable" eventho i'm sudo
Most likely your main root system is now mounted as readonly.
Also your third line is wrong, you either use the uid of the disk or the device name, not both.
I have mounted a seperate disk like this (I masked the uuid a bit).
First I create a directory like /backup2 on my / system.
Then added it like this in the /etc/fstab file:
UUID=39edf4f1-xxx-4677-xxx-79a4fd40bd01 /backup2   ext4   defaults   0   0
Then ran the command:
And ready. Also works after reboot.
Well, for now this makes me able to boot into alma, now DA doesnt run.
But will see that after i get DA to run (error opening mysql database error=dial tcp 127.0.0.1:3306: connect: connection refused)
Well, it's everything DA related that fails.
Your server still in read-only mode, that's why other service can't start/running.
So everything relate or not to DA will all fail.
It's alraedy partly fix via pm with @Zhenyapan and me so everything is running now again as before, but without the extra /home2 partition.
But he will try again tomorrow. I gave some tips for him to test if all is correct, before doing a reboot.
