S Stide Verified User Joined Oct 28, 2023 Messages 15 Feb 7, 2024 #1 I have a ubuntu 22.04, i first installed Odoo then nginx and everything was ok. But when i installed DirectAdmin, the Odoo and nginx became unreachable. Is it possible to have them working?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,165 Location www.poralix.com Feb 7, 2024 #2 Hello, If you had NGINX installed prior to DirectAdmin installation, then it's expected that it was removed. You can install NGINX with a help of DirectAdmin and configure a port forwarding using the following guide: https://help.poralix.com/articles/nginx-to-proxy-requests-to-custom-port-in-directadmin
S Stide Verified User Joined Oct 28, 2023 Messages 15 Feb 9, 2024 #3 zEitEr said: Hello, If you had NGINX installed prior to DirectAdmin installation, then it's expected that it was removed. You can install NGINX with a help of DirectAdmin and configure a port forwarding using the following guide: https://help.poralix.com/articles/nginx-to-proxy-requests-to-custom-port-in-directadmin Click to expand... Thank you sir, all works perfectly
