the ionCube Loader for PHP needs to be installed (8.2 php )
alinajafi
HI
I have 2 versions of PHP
1: 7.4
2: 8.2
the 7.4 have the ionCube
but 8.2 not
Custombuild, there you should see the option to build ioncube. for 8.2
CustomBuild --> Build --> ionCube
I'm running 8.3 and it builds for that, so i guess it should also for 8.2(?)
What if you build PHP 8.2 again? and after ioncube?
Also do you have it enabled in CustomBuild --> Options --> ioncube = yes?
Oh wait... Ioncube doesnt work with 8.x yet (at least on my server)
Edit it works with 8.1 and 8.2
It does, up to 8.2, not sure about 8.3
Later i edited my post, 8.1 and 8.2 are supported, 8.0 isnt
