The Scheduled FTP Backup is correctly set but not work at Premeditated time
alinajafi
Hi when I click on RUN NOW just its work
its not work an Premeditated time
server date correct? what shows:
systemctl status crond
First, we would need to see how you configured this task to run, then it would be helpful to see the log file that cron logs to, around the time you configured the task to run. If it ran, you will see it in the logs, if it failed, it should attempt to send an email to the user that created the cron job. If it was root, then also make sure you have a real user configured in your /etc/aliases to redirect all root emails to a real user.
