[How-To] Create or change your server's hostname in Directadmin
Richard G
Maastricht
This is a guide on how to create a correct FQDN hostname on a server or VPS.
I created this newly here in this section, for easier reference and it's also easier to find.
There is also another method, but the method described here is a method which is also still very usable.
Before you install Directadmin you can already take care the correct hostname is used bij Directadmin.
The domain mydomain.com is used her as example and 192.168.0.1 as example server ip. Ofcourse replace all examples with the domain or hostname your are using. So don't use 192.168.0.1 in the real situation, same for mydomain.com!
Commands before installation of DA:
Via SSH as root:
hostnamectl set-hostname server.mydomain.com
after that check your /etc/hostname file to see if the hostname is fully in there.
So it should read: server.mydomain.com
After that check your /etc/hosts file. Adjust it if needed. Should look like:
127.0.0.1 localhost.localdomain localhost
::1     ip6-localhost ip6-loopback
192.168.0.1 server.mydomain.com server
Just to be sure reboot your server/vps and issue these commands check if they return the correct hostname.
hostname
and
hostname -f
both commands should give the full server.mydomain.com hostname as a result.
Then your fine and the DA setup will take over your hostname.
Changing hostname after installation.
Check if the above settings are correct.
Then also change the hostname in Directadmin.
Login as admin, go to DNS administration, check for the server-xx-xx-xx-xx.da.direct and delete it if present.
Be aware! By default Directadmin also will set this as nameservers so like:
ns1.server-xx-xx-xx-xx.da.direct and
ns2.server-xx-xx-xx-xx.da.direct
which ofcourse also needs changing. Change that to for example ns1.mydomain.com and ns2.mydomain.com. You have to setup the nameservers and this can be done via DA too, but the howto is not included in this manual. It's just a reminder that it's best to change these defaults.
Then still under admin, in DNS administration, create your new hostname like you would for a domain. So use the "Add DNS zone" option.
You will have to fill in the server ip and the nameservers too.
Now there is a bug (might be solved at some point), so login to SSH and go to the /etc/virtual directory and make sure that the directory server.mydomain.com is present in there too., If not then create it and chown it to mail and chmod to 711.
Like this, but only if it does not exist yet.
cd /etc/virtual
mkdir server.mydomain.com
chown mail. server.mydomain.com
chmod 711 server.mydomain.com
If you are using an external nameserver, be sure to create the appropriate A record for the hostname there too.
That might need a bit of time to synchronise over wordly DNS, but after that your hostname should be working.
Additionally: Dont forget to create a new hostname certificate for your hostname.
As of Directadmin version 1.661 it's made easier and you can issue this new command:
./letsencrypt.sh server_cert
or just:
/usr/local/directadmin/scripts/letsencrypt.sh server_cert
Older DA versions use:
./letsencrypt.sh request_single server.mydomain.com 4096
NB! Often if the hostname is changed after installation, when trying to create a certificate for the hostname, LE will still try to get a certificate for the server-xx-xx-xx.da.direct hostname which is generated by the DA installation.
In that case doublecheck your /etc/hosts and /etc/hostname file that it contains your new hostname and the old is removed. If not, adjust the file(s) accordingly.
If that doesn't help, use the solution @zEitEr gave us, because that wil work for 100% sure.
Remove these files (as far as present) if the server.xx.xx.da.direct hostname stays present after a hostname change and everything is setup correctly:
  • /usr/local/directadmin/conf/ca.csr
  • /usr/local/directadmin/conf/ca.san_config
  • /usr/local/directadmin/conf/cacert.pem
  • /usr/local/directadmin/conf/cacert.pem.combined
  • /usr/local/directadmin/conf/cacert.pem.creation_time
  • /usr/local/directadmin/conf/cakey.pem
  • /usr/local/directadmin/conf/carootcert.pem
  • /usr/local/directadmin/conf/letsencrypt.key
  • /usr/local/directadmin/conf/letsencrypt.key.json
In this case LE can't use the old certificates anymore, which will fix the issue and you can request the hostname certificate again.
If mydomain.com is also created on the server, then the hostname record can also have SPF and even DKIM records created. This could come in handy when you have scripts using php mail() instead of SMTP. I would advise SMTP.
External nameserver usage.
Be aware!
If you set it up like this and create a DKIM record for your hostname, then this can be different from your mydomain.com DKIM record. So if you're using external nameservers/DNS for example like Cloudflare, you can't setup a seperate hostname dns record like in DA. So be sure to take over the DKIM record for your hostname too. You can have multiple DKIM records, that is no problem.
Probably you also need to include your hostname in the SPF record, I'm not 100% sure of that.
Hostnames and e-mail usage in all hostname cases.
If you are running e-mail from your server (default) then be sure to have a valid rDNS/PTR record for your hostname. You can normally set this in the control panel of the one who gave you the server ip, so mostly datacenter control panel or panel of VPS provider.
E-mail can be used without this, but many systems will raise spam points for this and it can easily lead to your e-mail being blocked if you don't have set this up correctly.
This guide will be adjusted as/if needed in the future.
Hahaha good idea :) now you can redirect people to this topic instead tell it over and over again
Why is it so hard to change the hostname after setup? Surely it should just be a case of updating it in CB
Yes it is, if you don't need a new hostname SSL certificate or mail from hostname and/or if everthing is working correctly. The basic change is mostly not hard at all.
But as you can read from the howto, there are cases in which not everything is change correctly and often the new SSL certificate gives issues. So it's written to also prevent/fix these issues if/when they arise.
Yep, sorry, what I meant was, surely updating in the CB should do all the change requirements.
Be aware! If you set it up like this and create a DKIM record for your hostname, then this can be different from your mydomain.com DKIM record. So if you're using external nameservers/DNS for example like Cloudflare, you can't setup a seperate hostname dns record like in DA. So be sure to take over the DKIM record for your hostname too. You can have multiple DKIM records, that is no problem
You will need to set the i= tag in the exim config for dkim alignment of these subdomains right?
Did you enter your hostname in web installer and it did not work?
Web installer failed, didn't want to fuss with trying to diagnose that issue since I didn't even know there was a web-installer as I've never used it in the past, so did the same installation method as always:
sh <(curl -fsSL https://download.directadmin.com/setup.sh) '__insert_your_license_key_here__'
Unsure what the technical challenge is of generating an SSL when the user updates the hostname in : Dashboard > Administrator Settings > Server Settings, since this specifically requires a FQDN that resolves to the main IP of the server, or why nothing noteworthy happens when adding the hostname in the "Admin SSL" or "Server TLS Certificate" pages. Users would still be presented with an SSL error upon going to https://hostname:2222
We only deploy a new DA server once every 8 months or so. Will likely come back to this thread at that time too to see what I need to do to get an SSL working for the server hostname.
One line should be sufficient for that once everything is setup correctly (also in this doc):
There are 2 ways, just use the hostname from DA and mention the hostname in the server domain.
However, I've not seen server ssl and dkim for the hostname working when having it like this, which is what you encounter. Might be fixed when using a wildcard record, but for wildcard records you have to use your own nameservers or use the LEGO option. Or maybe when entered separately entered, I don't know I never use that method anymore.
The way from using this manual has some benefits. You can seperately configure the hostname.
One of the benefits is that you can set a strict SPF record for the hostname domain (example.com) and a softfail for the hostname record (server.example.com) itself.
Also the above command will set the ssl for the hostname too without issues.
I've encountered some odd things a couple of times by using the alternative method, also with others I helped, which is the reason I wrote this manual.
But ofcourse everyone can feel free to use his own method.
In case anyone finds this later (Feb 2026) it appears the above is no longer true and the DA install script will always replace any previously set hostname, regardless of whether a FQDN hostname is already set, and regardless of the existence or contents of the DA_HOSTNAME environment variable. It's annoying and contrary to the documentation but at least it's predictable!
If the hostname is set properly (to a subdomain of a domain you own) and corresponding DNS records exist and have had time to propagate after the installation completes, everything is fine. The menu to do this is buried quite deep - I eventually found it under Admin > Server Manager > Administrator Settings > Server Settings > Server > Hostname. You may have to regenerate the TLS certificate (same menu) and reboot to see the full effect.
If the hostname is left as the default, everything is NOT fine - you will see security warnings when accessing the control panel due to the self-signed certificate, and outgoing mail will probably not be delivered to places like Gmail.
If that is the case, then it's clearly a bug and you should not report this to an installation guide like this, but in a seperate thread or in the release thread of the version since this is happening.
The hostname in the settings were you pointing to does not as much as normally is required which is pointed out in this guide! And also has little to do with the extra intention of this guide to have a -separate- hostname entry for SSL.
So please start a new topic and address this issue to DA if this does not work for you as it should work, also according to the docs.
I thought this behaviour might be by design (not a bug), because at least it should always work. Whereas, if the previous hostname or the contents of DA_HOSTNAME are incorrect or even if the DNS has not yet had time to propagate then bad things will happen and the installation will essentially fail. I was therefore holding back on raising a bug.
Similarly, I've seen conflicting advice about whether the hostname should be added as one of the hosted domains or not so I was holding back on that as well. I don't know what the "alternative method" is so more research required.
I really appreciate having a "how to" like this that lists what DOES work, rather than all the complaints about the things that don't. It's just that I thought it was probably out of date and needed a warning.
I can understand, but the docs also state that you should be able to use the DA_HOSTNAME and other commands during installation.
That is no conflicting information, that is just another way of working with the hostname depending on the needs. I mentioned that as other method in the 3rd line of my guide (first post).
It all depends for example of you want mails also to be send via the hostname, for example by php scripts via php mail and some other things like easy get an SSL for the hostname, which requires customisation in the directadmin.conf for the other method.
This guide is the extended method and should always work.
The other method is using the hostname as you described via settings and then use the hostname in the DNS of one of the hosted domains (like a subdomain). Needs other adjustments as described but I didn't want ot make a guide of that, I leave that to others.
Anyway, now you now it's not conflicting information, just another way of working with the hostname, depending on the needs.
Yes but it's just a little more than a year old, I do understand your way of thinking. But in that case it's better to ask if something is still working, then making a statement (even with bold characters) that something isn't working anymore nowadays withoug being 100% sure.
