Hi everyone,
I have changed my SSH port as well as my DA port to something else than 22 / 2222.
Is it safe to remove those ports from the csf firewall configuration then?
yes, you can also add your current IP to allowed - so for you all ports will be visible.
then you can try connect from different IP to be sure all works fine.
Also don't forget to change ssh port in CSF so it will monitor it instead of old 22
