jeefymirhdflc
- Apr 15, 2024
Hello
In our company we encourage a problem when customer add new user in DA panel , its rewriting file /etc/httpd/conf/ips.conf to content :
DirectAdmin v.1.658
And after reload/restart apache main domain of server fail to work with ssl , normaly /etc/httpd/conf/ips.conf shoud have content
Why does directadmin do this and how to correct it so that the file is not corrupted.
DirectAdmin v.1.658
# Auto generated apache config file by DirectAdmin version 1.658
# Modifying this file is not recommended as any changes you make will be
# overwritten when you add/remove ip's through DirectAdmin.
LogFormat "%O \"%r\"" homedir
<VirtualHost xxx:80>
ServerName shared.domain
UserDir disabled
DocumentRoot /home/admin/domains/sharedip
SuexecUserGroup admin admin
CustomLog /var/log/httpd/homedir.log homedir
CustomLog /var/log/httpd/access_log combined
</VirtualHost>
<VirtualHost xxx:443>
SSLEngine on
SSLCertificateFile /etc/httpd/conf/ssl.crt/server.crt
SSLCertificateKeyFile /etc/httpd/conf/ssl.key/server.key
SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca
UserDir disabled
</VirtualHost>
