R=smart_route defer (-1): remote host address is the local host *** Frozen
ahsanlodhi
i get this error when i try to send mail to gmail or receieve mail
"R=smart_route defer (-1): remote host address is the local host
*** Frozen"
i tried this method with authentication and its not working, i have also allowed port 25 through configserver security & firewall but still i get this error. i have added mx record for smtp and mail still i am getting this error
Which remote host are you using exactly? Because it seems (due to the error) that you are using an smtp name which is present on your server.
Remote mailserver usage is only used if your server can't send mail itself. And then the remote domain name should not be present as domain on your local server. It's an external service.
i get this error even after increasing it to 50 point from 10
here a dns mx record i get in response when i check it from dns checker
50:mail.domainname.com.
here my exim.conf code
note: 192.1222.1191.0 is dummy record for thread
smart_route:
driver = manualroute
domains = ! +local_domains
ignore_target_hosts = 127.0.0.0/8
condition = "${perl{check_limits}}"
route_list = !+local_domains 192.1222.1191.0
transport = remote_smtp
You did not work according to the docs.
You have:
Docs say:
route_list = * smtp.external.com
Also, you used the wrong order, that can make a difference too in some cases.
You have:
should be like this without the local domains and other order and thing added:
route_list = * smtp.externaldomain.com
no_more
Maybe change this and then things will work.
Ofcourse change smtp.externaldomain.com with the correct domain value.
this is what error i get i tried increased value to 50 from 10 still have this issue there.
