zomebodi Verified User Joined Sep 3, 2023 Messages 66 Jun 4, 2024 #1 i cant find it on /etc/ or /etc/clamd/
Richard G Verified User Joined Jul 6, 2008 Messages 14,940 Location Maastricht Jun 4, 2024 #2 It's the /etc/clamd.d/scan.conf file Also you can configure the /etc/freshclam.conf file for options. At least for RHEL/Centos/Alma
zomebodi Verified User Joined Sep 3, 2023 Messages 66 Jun 4, 2024 #3 Thanks Richard If i edit /etc/clamd.d/scan.conf, this setting can be removed after update clamd?
Richard G Verified User Joined Jul 6, 2008 Messages 14,940 Location Maastricht Jun 4, 2024 #4 You're welcome. What do you mean removed? What do you want to remove after a clamd update and why?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,274 Location www.poralix.com Jun 4, 2024 #5 zomebodi said: If i edit /etc/clamd.d/scan.conf, this setting can be removed after update clamd? Click to expand... Since the software is installed from OS repository, the customized config file will survive an update. Your changes will remain untouched by Directadmin/Custombuild.
