- Aug 30, 2021
Thanks for sharing you use case @nlaruelle.
The situation is quite tricky. We do not want to completely ignore file ownership change errors, because it could mask unexpected problems in various places.
It would be the best if you could enable file ownership support on the NFS server, but I assume server side is outside of your control.
Would it be possible for you could open a ticket and grant us access to the server with this problem? We would like to check what king of restrictions are applied on the NFS mount. Ideally we would prefer to handle such environment without errors and without adding extra configuration options to manually ignore errors.
