Can't Connect to Mail Server
codes9
I started having issues connecting to imap and smtp from Thunderbird for several domains.
Get "error connecting to ... connection refused"
Been using Roundcube as a fallback. That ran into issues as well during today.
After a full CustomBuild rebuild I can send and receive from Roundcube at least.
However I still can't get Thunderbird to send or receive without hitting connection refused errors.
Using Roundcube for multiple mailboxes is quite a chore.
I checked that my IP did not land on not on the CSF blocklist.
I've attempted to clear up some of the index errors I'm seeing for Dovecot. But so far none of this really helps any mailboxes become functional in anything but Roundcube.
And I've also added autoconfig to domains that struggle to try and help Thunderbird discovery along. Even if I add settings manually I can't get Thunderbird to connect anymore to new email addresses. Curiously an email address I added before seems to work.
Wondering if this is a Thunderbird issue or a DirectAdmin issue. I'm trying another mail client next and will keep you posted.
Exim Mainlog
2024-09-11 22:53:47 1soULT-00000004Gul-0Fyp failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:53:47 1soULT-00000004Gul-0Fyp == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:53:47 1soULT-00000004Gul-0Fyp ** [email protected]: retry timeout exceeded
2024-09-11 22:53:47 1soULT-00000004Gul-0Fyp [email protected]: error ignored
2024-09-11 22:53:47 1soULT-00000004Gul-0Fyp Completed
2024-09-11 22:55:47 cwd=/etc/csf 4 args: /usr/sbin/sendmail -f root -t
2024-09-11 22:55:47 1soUNP-00000004GwF-0djF <= [email protected] U=root P=local S=627 T="lfd on 26.hostingserver.co.za: SYSLOG Check Failed" from <[email protected]> for root
2024-09-11 22:55:47 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1soUNP-00000004GwF-0djF
2024-09-11 22:55:47 1soUNP-00000004GwF-0djF failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:55:47 1soUNP-00000004GwF-0djF == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:55:47 1soUNP-00000004GwF-0djF ** [email protected]: retry timeout exceeded
2024-09-11 22:55:47 cwd=/var/spool/exim 7 args: /usr/sbin/exim -t -oem -oi -f <> -E1soUNP-00000004GwF-0djF
2024-09-11 22:55:47 1soUNP-00000004GwL-0zIy <= <> R=1soUNP-00000004GwF-0djF U=mail P=local S=1983 T="Mail delivery failed: returning message to sender" from <> for [email protected]
2024-09-11 22:55:47 1soUNP-00000004GwF-0djF Completed
2024-09-11 22:55:47 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1soUNP-00000004GwL-0zIy
2024-09-11 22:55:47 1soUNP-00000004GwL-0zIy failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:55:47 1soUNP-00000004GwL-0zIy == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:55:47 1soUNP-00000004GwL-0zIy ** [email protected]: retry timeout exceeded
2024-09-11 22:55:47 1soUNP-00000004GwL-0zIy [email protected]: error ignored
2024-09-11 22:55:47 1soUNP-00000004GwL-0zIy Completed
2024-09-11 22:56:47 cwd=/etc/csf 4 args: /usr/sbin/sendmail -f root -t
2024-09-11 22:56:47 1soUON-00000004Gwu-1MXd <= [email protected] U=root P=local S=615 T="lfd on 26.hostingserver.co.za: Suspicious File Alert" from <[email protected]> for root
2024-09-11 22:56:47 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1soUON-00000004Gwu-1MXd
2024-09-11 22:56:47 1soUON-00000004Gwu-1MXd failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:56:47 1soUON-00000004Gwu-1MXd == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:56:47 1soUON-00000004Gwu-1MXd ** [email protected]: retry timeout exceeded
2024-09-11 22:56:47 1soUON-00000004Gwx-1ZoJ <= [email protected] U=root P=local S=629 T="lfd on 26.hostingserver.co.za: Suspicious File Alert" from <[email protected]> for root
2024-09-11 22:56:47 cwd=/var/spool/exim 7 args: /usr/sbin/exim -t -oem -oi -f <> -E1soUON-00000004Gwu-1MXd
2024-09-11 22:56:47 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1soUON-00000004Gwx-1ZoJ
2024-09-11 22:56:47 1soUON-00000004Gwx-1ZoJ failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:56:47 1soUON-00000004Gwx-1ZoJ == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:56:47 1soUON-00000004Gwx-1ZoJ ** [email protected]: retry timeout exceeded
2024-09-11 22:56:47 cwd=/var/spool/exim 7 args: /usr/sbin/exim -t -oem -oi -f <> -E1soUON-00000004Gwx-1ZoJ
2024-09-11 22:56:47 1soUON-00000004Gx1-1lYI <= <> R=1soUON-00000004Gwu-1MXd U=mail P=local S=1976 T="Mail delivery failed: returning message to sender" from <> for [email protected]
2024-09-11 22:56:47 1soUON-00000004Gwu-1MXd Completed
2024-09-11 22:56:47 1soUON-00000004Gx6-1tLH <= <> R=1soUON-00000004Gwx-1ZoJ U=mail P=local S=1990 T="Mail delivery failed: returning message to sender" from <> for [email protected]
2024-09-11 22:56:47 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1soUON-00000004Gx1-1lYI
2024-09-11 22:56:47 1soUON-00000004Gwx-1ZoJ Completed
2024-09-11 22:56:47 1soUON-00000004Gx1-1lYI failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:56:47 1soUON-00000004Gx1-1lYI == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:56:47 1soUON-00000004Gx1-1lYI ** [email protected]: retry timeout exceeded
2024-09-11 22:56:47 1soUON-00000004Gx1-1lYI [email protected]: error ignored
2024-09-11 22:56:47 1soUON-00000004Gx1-1lYI Completed
2024-09-11 22:56:47 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1soUON-00000004Gx6-1tLH
2024-09-11 22:56:47 1soUON-00000004Gx6-1tLH failed to expand "${if match {$local_part}{\N^\.*[^./][^/]*$\N}{${lookup{$local_part}lsearch,ret=key{/etc/aliases}{$value}}}fail}" while checking a list: failed to open /etc/aliases for linear search: No such file or directory
2024-09-11 22:56:47 1soUON-00000004Gx6-1tLH == [email protected] R=system_aliases defer (-1): local_parts check lookup or other defer
2024-09-11 22:56:47 1soUON-00000004Gx6-1tLH ** [email protected]: retry timeout exceeded
2024-09-11 22:56:47 1soUON-00000004Gx6-1tLH [email protected]: error ignored
2024-09-11 22:56:47 1soUON-00000004Gx6-1tLH Completed
Exim Reject Log
2024-09-09 11:13:52 H=(friendlyt.nzrswzkt2woelgdcyr0x4kjzne.cx.internal.cloudapp.net) [40.70.44.101] F=<[email protected]> rejected RCPT <[email protected]>: relay not permitted, authentication required
2024-09-09 12:18:30 H=agree.siglamag.com [193.25.216.98] X=TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256:128 CV=no F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-09 13:54:39 SMTP call from scan-08.shadowserver.org [216.218.206.69] dropped: too many unrecognized commands (last was "Accept: */*")
2024-09-09 15:52:48 SMTP call from [115.231.78.3] dropped: too many syntax or protocol errors (last command was "?\034?\032?\027?\031?\034?\033?\030?\032?\026?\016?\r?\v?\f? ?", NULL)
2024-09-09 16:09:36 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-09 20:15:10 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-09 20:26:37 SMTP call from [94.141.120.204] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip, deflate")
2024-09-10 03:04:21 SMTP call from [115.231.78.3] dropped: too many syntax or protocol errors (last command was "?\034?\032?\027?\031?\034?\033?\030?\032?\026?\016?\r?\v?\f? ?", NULL)
2024-09-10 03:19:48 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-10 04:37:02 SMTP call from [2604:a940:302:118:0:23::] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip")
2024-09-10 07:20:19 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-10 08:08:08 SMTP call from [2604:a940:301:225:0:f::] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip")
2024-09-10 10:32:22 H=(a.dkfjksarwe.ru) [45.202.32.10] X=TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256:128 CV=no F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-10 11:01:42 SMTP call from [198.235.24.88] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip")
2024-09-10 12:30:51 H=ms140.elara4mail.com [162.251.4.140] X=TLS1.3:TLS_AES_256_GCM_SHA384:256 CV=no F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-10 13:34:08 H=de1-mail-201.bouncer.cloud [51.89.124.10] F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-10 13:59:51 SMTP call from [115.231.78.3] dropped: too many syntax or protocol errors (last command was "?\033?/?4�\020�\006�\025�\v�\001?;�0�,�(�$�\024�", NULL)
2024-09-10 14:06:11 SMTP call from scan-46j.shadowserver.org [64.62.197.86] dropped: too many unrecognized commands (last was "Accept: */*")
2024-09-10 14:16:22 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-10 14:30:25 H=mail.modulesgarden.com [178.63.184.233] X=TLS1.3:TLS_AES_256_GCM_SHA384:256 CV=no F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-10 14:36:21 SMTP call from [152.32.243.245] dropped: too many syntax or protocol errors (last command was "?", NULL)
2024-09-10 16:02:24 H=s946973.srvape.com [188.127.247.77] F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-10 18:25:11 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-10 20:19:32 rejected EHLO from portscanner-fra1-03.prod.cyberresilience.io [46.101.122.229]: syntactically invalid argument(s): (no argument given)
2024-09-11 01:14:58 SMTP call from [115.231.78.3] dropped: too many syntax or protocol errors (last command was "?\034?\032?\027?\031?\034?\033?\030?\032?\026?\016?\r?\v?\f? ?", NULL)
2024-09-11 01:30:34 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-11 04:28:58 H=mail-lj1-f175.google.com [209.85.208.175] X=TLS1.3:TLS_AES_256_GCM_SHA384:256 CV=no F=<[email protected]> rejected RCPT <[email protected]>:
2024-09-11 04:43:32 plain authenticator failed for (gmail.com) [80.66.83.33]: 535 Incorrect authentication data (set_id=[email protected])
2024-09-11 04:44:53 plain authenticator failed for (gmail.com) [80.66.83.33]: 535 Incorrect authentication data (set_id=[email protected])
2024-09-11 04:46:57 plain authenticator failed for (gmail.com) [80.66.83.33]: 535 Incorrect authentication data (set_id=[email protected])
2024-09-11 05:31:56 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-11 06:26:47 SMTP call from [2604:a940:302:118:0:23::] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip")
2024-09-11 07:31:19 SMTP call from scan-60-12.shadowserver.org [64.62.156.22] dropped: too many unrecognized commands (last was "Accept: */*")
2024-09-11 08:14:51 SMTP call from [205.210.31.131] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip")
2024-09-11 09:46:41 login authenticator failed for (User) [94.141.120.77]: 535 Incorrect authentication data (set_id=root)
2024-09-11 09:51:24 login authenticator failed for (User) [94.141.120.77]: 535 Incorrect authentication data (set_id=test )
2024-09-11 09:56:00 login authenticator failed for (User) [94.141.120.77]: 535 Incorrect authentication data (set_id=user )
2024-09-11 10:01:14 login authenticator failed for (User) [94.141.120.77]: 535 Incorrect authentication data (set_id=test )
2024-09-11 10:05:23 login authenticator failed for (User) [94.141.120.77]: 535 Incorrect authentication data (set_id=ubuntu )
2024-09-11 10:38:30 login authenticator failed for (USER) [45.148.10.171]: 535 Incorrect authentication data (set_id=cumplmsameargaasta193)
2024-09-11 12:14:18 SMTP call from [115.231.78.3] dropped: too many syntax or protocol errors (last command was "?\034?\032?\027?\031?\034?\033?\030?\032?\026?\016?\r?\v?\f? ?", NULL)
2024-09-11 12:30:04 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-11 12:39:28 login authenticator failed for (User) [194.169.175.47]: 535 Incorrect authentication data (set_id=[email protected])
2024-09-11 16:36:41 rejected EHLO from [115.231.78.3]: syntactically invalid argument(s): []
2024-09-11 17:33:40 SMTP call from morgan.probe.onyphe.net [213.32.25.76] dropped: too many syntax or protocol errors (last command was "?\035?\027?\036?\031?\030?\026???\027???\r?*?(\004\003\005\003\006\003\b\007\b\b\b \b", NULL)
2024-09-11 18:23:37 SMTP call from [185.91.69.33] dropped: too many unrecognized commands (last was "Cache-Control: max-age=0")
2024-09-11 22:09:57 SMTP call from [198.235.24.231] dropped: too many unrecognized commands (last was "Accept-Encoding: gzip")
/var/log/mail.err -- Followed https://serverfault.com/questions/1103975/dovecot-corrupted-record-in-index-cache-file to clear this up.
Sep 11 22:55:40 26 dovecot[1003000]: imap([email protected])<1018418><ispLNt4hvH4pljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:55:40 26 dovecot[1003000]: imap([email protected])<1018418><ispLNt4hvH4pljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 22:55:43 26 dovecot[1003000]: imap([email protected])<1018420><+tqINt4hIqEpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 22:55:43 26 dovecot[1003000]: imap([email protected])<1018420><+tqINt4hIqEpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:55:43 26 dovecot[1003000]: imap([email protected])<1018420><+tqINt4hIqEpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 22:55:47 26 dovecot[1003000]: imap([email protected])<1018422><6OS/Nt4hJBkpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 22:55:47 26 dovecot[1003000]: imap([email protected])<1018422><6OS/Nt4hJBkpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:55:47 26 dovecot[1003000]: imap([email protected])<1018422><6OS/Nt4hJBkpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 22:55:51 26 dovecot[1003000]: imap([email protected])<1018439><SN36Nt4hWTwpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 22:55:51 26 dovecot[1003000]: imap([email protected])<1018439><SN36Nt4hWTwpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:55:51 26 dovecot[1003000]: imap([email protected])<1018439><SN36Nt4hWTwpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 22:55:55 26 dovecot[1003000]: imap([email protected])<1018441><On4xN94hPhkpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 22:55:55 26 dovecot[1003000]: imap([email protected])<1018441><On4xN94hPhkpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:55:55 26 dovecot[1003000]: imap([email protected])<1018441><On4xN94hPhkpljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 22:55:58 26 dovecot[1003000]: imap([email protected])<1018443><l0drN94hqH4pljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 22:55:58 26 dovecot[1003000]: imap([email protected])<1018443><l0drN94hqH4pljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:55:58 26 dovecot[1003000]: imap([email protected])<1018443><l0drN94hqH4pljFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 22:56:02 26 dovecot[1003000]: imap([email protected])<1018445><jvahN94hpW8pkdFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 22:56:02 26 dovecot[1003000]: imap([email protected])<1018445><jvahN94hpW8pkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 22:56:02 26 dovecot[1003000]: imap([email protected])<1018445><jvahN94hpW8pkdFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 23:05:54 26 dovecot[1019023]: imap([email protected])<1019168></sjYWt4hXTwpljFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:05:54 26 dovecot[1019023]: imap([email protected])<1019168></sjYWt4hXTwpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:05:54 26 dovecot[1019023]: imap([email protected])<1019168></sjYWt4hXTwpljFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:05:59 26 dovecot[1019023]: imap([email protected])<1019170><B0cnW94hZsQpljFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:05:59 26 dovecot[1019023]: imap([email protected])<1019170><B0cnW94hZsQpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:05:59 26 dovecot[1019023]: imap([email protected])<1019170><B0cnW94hZsQpljFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:03 26 dovecot[1019023]: imap([email protected])<1019172><PRVuW94hd38pkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:06:03 26 dovecot[1019023]: imap([email protected])<1019172><PRVuW94hd38pkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:06:03 26 dovecot[1019023]: imap([email protected])<1019172><PRVuW94hd38pkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:07 26 dovecot[1019023]: imap([email protected])<1019174><oFKmW94hKaEpljFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:06:07 26 dovecot[1019023]: imap([email protected])<1019174><oFKmW94hKaEpljFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:06:07 26 dovecot[1019023]: imap([email protected])<1019174><oFKmW94hKaEpljFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:11 26 dovecot[1019023]: imap([email protected])<1019176><aJPsW94h0PgpkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:06:11 26 dovecot[1019023]: imap([email protected])<1019176><aJPsW94h0PgpkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:06:11 26 dovecot[1019023]: imap([email protected])<1019176><aJPsW94h0PgpkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:15 26 dovecot[1019023]: imap([email protected])<1019178><2yIwXN4h0/gpkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:06:15 26 dovecot[1019023]: imap([email protected])<1019178><2yIwXN4h0/gpkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:06:15 26 dovecot[1019023]: imap([email protected])<1019178><2yIwXN4h0/gpkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:19 26 dovecot[1019023]: imap([email protected])<1019180><Z6tpXN4hYSopkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:06:19 26 dovecot[1019023]: imap([email protected])<1019180><Z6tpXN4hYSopkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:06:19 26 dovecot[1019023]: imap([email protected])<1019180><Z6tpXN4hYSopkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:23 26 dovecot[1019023]: imap([email protected])<1019196><LDWnXN4h8xspkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (read reason=mail stream)
Sep 11 23:06:23 26 dovecot[1019023]: imap([email protected])<1019196><LDWnXN4h8xspkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=447: UID 447: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447)
Sep 11 23:06:23 26 dovecot[1019023]: imap([email protected])<1019196><LDWnXN4h8xspkdFb>: Error: Mailbox INBOX: UID=447: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1644995726.M834584P1086292.20.atservice.co.za,S=27713,W=28210:2,Sa) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=447) (FETCH BODY[])
Sep 11 23:06:27 26 dovecot[1019023]: imap([email protected])<1019198><NdHeXN4h5wUpkdFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 23:06:27 26 dovecot[1019023]: imap([email protected])<1019198><NdHeXN4h5wUpkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 23:06:27 26 dovecot[1019023]: imap([email protected])<1019198><NdHeXN4h5wUpkdFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
Sep 11 23:06:31 26 dovecot[1019023]: imap([email protected])<1019209><qrgbXd4h2hcpkdFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (read reason=mail stream)
Sep 11 23:06:31 26 dovecot[1019023]: imap([email protected])<1019209><qrgbXd4h2hcpkdFb>: Error: Mailbox INBOX: Deleting corrupted cache record uid=461: UID 461: Broken physical size in mailbox INBOX: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461)
Sep 11 23:06:31 26 dovecot[1019023]: imap([email protected])<1019209><qrgbXd4h2hcpkdFb>: Error: Mailbox INBOX: UID=461: read(/home/admin/imap/rine.co.za/barco/Maildir/cur/1645600335.M925288P145722.23.hostingserver.co.za,S=27713,W=28210:2,S) failed: Cached message size larger than expected (27713 > 1438, box=INBOX, UID=461) (FETCH BODY[])
/var/log/mail.log
Sep 11 23:05:54 26 dovecot[1019023]: imap([email protected])<1019168></sjYWt4hXTwpljFb>: Disconnected: FETCH read() failed in=167 out=96881 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:05:56 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.150.49.91, lip=107.155.122.89, mpid=1019170, TLS, session=<B0cnW94hZsQpljFb>
Sep 11 23:05:59 26 dovecot[1019023]: imap([email protected])<1019170><B0cnW94hZsQpljFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:00 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019172, TLS, session=<PRVuW94hd38pkdFb>
Sep 11 23:06:03 26 dovecot[1019023]: imap([email protected])<1019172><PRVuW94hd38pkdFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:04 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.150.49.91, lip=107.155.122.89, mpid=1019174, TLS, session=<oFKmW94hKaEpljFb>
Sep 11 23:06:07 26 dovecot[1019023]: imap([email protected])<1019174><oFKmW94hKaEpljFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:09 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019176, TLS, session=<aJPsW94h0PgpkdFb>
Sep 11 23:06:11 26 dovecot[1019023]: imap([email protected])<1019176><aJPsW94h0PgpkdFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:13 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019178, TLS, session=<2yIwXN4h0/gpkdFb>
Sep 11 23:06:15 26 dovecot[1019023]: imap([email protected])<1019178><2yIwXN4h0/gpkdFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:17 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019180, TLS, session=<Z6tpXN4hYSopkdFb>
Sep 11 23:06:19 26 dovecot[1019023]: imap([email protected])<1019180><Z6tpXN4hYSopkdFb>: Disconnected: FETCH read() failed in=167 out=96881 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:21 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019196, TLS, session=<LDWnXN4h8xspkdFb>
Sep 11 23:06:23 26 dovecot[1019023]: imap([email protected])<1019196><LDWnXN4h8xspkdFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:25 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019198, TLS, session=<NdHeXN4h5wUpkdFb>
Sep 11 23:06:27 26 dovecot[1019023]: imap([email protected])<1019198><NdHeXN4h5wUpkdFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:06:29 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=41.145.209.91, lip=107.155.122.89, mpid=1019209, TLS, session=<qrgbXd4h2hcpkdFb>
Sep 11 23:06:30 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=1019211, secured, session=<b/c3Xd4hULF/AAAB>
Sep 11 23:06:30 26 dovecot[1019023]: imap([email protected])<1019211><b/c3Xd4hULF/AAAB>: Disconnected: Logged out in=91 out=1036 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Sep 11 23:06:31 26 dovecot[1019023]: imap([email protected])<1019209><qrgbXd4h2hcpkdFb>: Disconnected: FETCH read() failed in=167 out=96873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=1 body_bytes=1484
Sep 11 23:07:30 26 dovecot[1019023]: imap-login: Login: user=<[email protected]>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=1019247, secured, session=<UZHKYN4hNLR/AAAB>
Sep 11 23:07:30 26 dovecot[1019023]: imap([email protected])<1019247><UZHKYN4hNLR/AAAB>: Disconnected: Logged out in=91 out=1036 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Looks to me this might be causing the culprit. Did you delete the aliases file or something? Can you check if it's present?
