Can someone point me in the right direction please
Hi Everyone.,
What is the correct way of installing PHP 8.3 in to a Direct admin that has been using PHP 8.1 .
Can someone point me in the right direction please.I am new to direct admin.
thanks in advance
Hello, please I want to install PHP 8.4 on my DirectAdmin, I tried to follow this guideline but I didn't see the custom build on my Admin under Extra Features.As @ericosman said - use CustomBuild.
When logged in as admin user, go to Extra Features -> CustomBuild -> Options. Then select the PHP versions needed (php1_release being the default). Then go back to CustomBuild -> Updates and hit the "Update All" button.
When that is done, log in as the user you need to change PHP version for, got to Account Manager -> PHP Settings and select the PHP version you want to use for the specific domain.
Hi,Hello, please I want to install PHP 8.4 on my DirectAdmin, I tried to follow this guideline but I didn't see the custom build on my Admin under Extra Features.
I'm using DA Personal Plus License
Thank you for your help and support
Thank you for your response but the issue has been resolved I found another tutorial on Google and I follow it to install the PHP 8.4Hi,
Feel free to contact me for some help![]()
