Johnws2022
- Jan 14, 2022
Dear Sir,
Yesterday I was working on one of my websites on the hosting server using Direct Admin; there is errors due to missing some files in functions.php which I fixed straight away. My website in question has worked well since then.
However, about an hour ago, there is a database error like:
when trying to access WP Admin panel or even front end pages.
I then when to check in DA --> Databases, and found out all databases including the ones used by my other websites have gone; and I have not even able to create a new database. And I could not even access phpMyAdmin from DA control panel.
What could cause such an issue? Has hackers destroyed my databases or server?
Very appreciate your kind support.
Regards
Error establishing a database connection
This either means that the username and password information in your wp-config.php file is incorrect or that contact with the database server at 127.0.0.1 could not be established. This could mean your host’s database server is down.- Are you sure you have the correct username and password?
- Are you sure you have typed the correct hostname?
- Are you sure the database server is running?
Regards
