Enquiry - Any way to detect look-alike domain in SpamAssassin?
ccto
Hong Kong
To reduce look-alike domain phishing between from-domain and to-domain, any way to detect it?
For example, our customer domain says 123.com
spammer registers l23.com , setup those SPF,DKIM,..., and then it passes all anti-spam, and send the phishing emails.
Thank you for your advice.
v=spf1 a mx -all
Normally, directadmin will create with " ~all ", this will less strict. If really want to reject, must changing into " -all ".
Or maybe I'm wrong, if this isn't enought. @mxroute could solves this problem.
This indeed isn't enough because the spammer is not spoofing the domain but using a real domain which looks alike, so no spf or dkim will block that. But -all can be helpfull with "normal" spoofers.
@ccto Might be good to put that look-alike-domain in the /etc/virtual/blacklist_domains and maybe like *@I123.com (using your example) in the /etc/virtual/blacklist_senders file. Restart Exim aftwards.
However, this will not block that spammer from sending phishing mails to other servers.
But indeed maybe @mxroute has additional nice idea's.
Sieve filter can put regex expression to automatics deleted email.
Other feature like Spamassassin or Email Filter don't support regex rules. so this could filter look-alike domain out of mailbox.
