Note: the previous Let's Encrypt config is still set to renew in 4750 days.
giaogiao
USER >SSL Certificates
I Paste a pre-generated certificate and key
SAVE
Then shows
If you do not wish to overwrite the current certificate, please disable the auto-renewal
how to disable the auto-renewal?
No relevant options were found in the panel.
please tell me how to do this?
Go to your domain in Directadmin. Click to visit the SSL page.
There should be an option "disable auto-renew" on the bottom of the page somewhere or butten on the middle of the page on the right hand side. It's at the same tab where you pasted youw pre-generated key.
no see "disable auto-renew" 😭
I do see it in mine. Seems like you have a customized skin because you have selection buttons, and I've seen tabs. Maybe try Enhanced skin and see if you can disable it there.
It should be there on the screenshot between "Certificate" and "Certificates Host" a line is missing with text "ACME in use. Auto Renewal in xx Days" .. and on the right end of this a line a green button should be there "Disable Auto-Renews". Do as @Richard told you, try another skin.
Even when clicken "disable autorenew" before saving the new certificate i get the message "Note: the previous Let's Encrypt config is still set to renew in x days".
When I then press the disable auto renew button you would think everything is fine. Paste the same certificate information again, and I get "Note: the previous Let's Encrypt config is still set to renew in x days".
Also, when clicking the Back link, "I get a message saying the domain doens't belong to you". Refresh doesn't help. Have to go back home. When I got the SSL certificate again the bahaviour stays the same.
Same problem in the evolution skin.
Enhanced sknin works, it ask after updating "
Note: the previous Let's Encrypt config is still set to renew in 377 days.
" and then it shows an button disable but i keep switching :(
