Exim rejecting mail: “Remote host address is the local host”
twv
I retired an old server (old.server.com) and moved its accounts to a new server (new.server.com). The A record for old.server.com points to new.server.com. Exim is rejecting mail to [email protected] with the message “[email protected] R=lookuphost defer (-1): remote host address is the local host”
How can I get exim to accept the mail and deliver it to [email protected]?
Just one question. If you retire a server, why would you still want to send mail from the old hostname?
What you want is not possible since the hostname is not a domain and does not have an MX page where you can deselect the option to "handle this server for my mail".
So obviously mail send to [email protected] will be seen as send to localhost.
It's better to just put it down. Normally DNS synch is only a few hours. Mail being which is send during that time is mostly delayed and retried after a certain amount of hours.
Or if you want to keep things until resolving, then you can use rsync to synchronise e-mail accounts.
I don’t want to send from that domain. I want to receive mail to that domain. The reason is that I use [email protected] in lots of monitoring setups and I want to receive any notices until I get a chance to update the setups.
Since Exim rejected it, have you already tried putting it in one or more of Exim's whitelists in the /etc/virtual directory?
Like whitelist_domains or whitelist_from for example? You can even use multiple.
Good idea, but it doesn’t seem to change it.
I found this: “remote host address is the local host is an exim error message which indicates that the sender or recipient's domain has your machine's hostname/IP, but exim is not configured to accept mail for that domain.” from this thread: https://forum.directadmin.com/threads/exim-mainlog-temporarily-rejected-rcpt.60529/ , but I haven’t figured out how to configure exim to accept mail for the old hostname.
I know it's an Exim error message. ;)
That is odd, because whitelists should overrule that anyway. Did you tried multiple whitelists and also restart Exim after making the additions?
But it's a bit confusing anyway.
To be able to receive something, something else needs to be sending things even if it's to localhost. So your old server is sending, that is what I mean.
Now what exactly is it about. Is it a hostname or is it a domain?
Because if it's a domain, then a better example would be user@oldserverdomain and user@newserverdomain otherwise I think it's a hostname.
Also I don't know if (in case of a hostname) it's smart in this case, to point to A record to the new server's ip, maybe it's better to use another solution.
But I'm just fishing, way too little info to be able to give a good advise further.
Maybe fastes is to quickly start changing the mails in the monitoring tools.
It’s a FQDN. DA does support multiple FQDNs -- for example, you can configure DA to include additional FQDNs in your server certificate. It’s not a big deal. I will just update the monitors.
