Cannot connect to mail server - fresh install
dorucrisan
Bucharest / Romania
I cannot connect to mail server on fresh install. This was after replacing the server (computer), same IP same everything. Error message says something about encription but mail domain has SSL. Also changed encryption type, even without encryption (port 25) same situation. Cannot connect to Round Cube either, does not recognize credentials. Done many other installs, never seen this.
Any idea?
The error in the screenshot has nothing to do with a SSL certificate installed on the domain. It is about TLS/SSL encryption you use for connecting to IMAP/POP/SMTP.
In order to give you more ideas, you would need to give us your server's IP or hostname, so that we could check it from our side.
Thank you so much, IP- 82.76.52.228 , host name - host.cctvforum.ro . On the previous machine it worket without issues for 2 years. Did not changed anything except the machine. Is it possible to be install problem? Should I reinstall DA?
