Certificate issue with DirectAdmin
nservices
in DirectAdmin last version, I have installed updated ssl, attaching screenshots
checked, files are correct and updated, directadmin.conf settings are correct
any suggestion?
You're using mypanel.domain.tld:2222 instead of just domain.tld:2222 so there is some customisation in place probably.
That customisation could be causing the issue. If you did not customize anything, don't use mypanel, just use domain.tld:2222 and things should be in good order.
mypanel.domain.tld is the hostname and the panel name
the ssl created for mypanel.domain.tld and should work, in all other servers it's work, only in this case not
Kind Regards,
Ah oke, if that is your hostname, then it's all good. I thought you created a seperate subdomain for visiting the panel, some people do.
Check your directadmin.conf please if you got this setting in there:
ssl=1
(and yes it must be lowercase) if not present, just to be sure add it and after that restart directadmin. Does that fix things for you?
ssl=1
thanks!
alerady set
ssl=1
port=2222
it's not working, I try even manually set the crt files on directadmin.conf and check them manually (they OK)
no vhost under this name (it's work and show directadmin panel, but with SSL alert)
other suggestions?
That is odd.
Do you have a seperate hostname entry in DNS? So not added mypanel to domain.tld but a seperate entry for mypanel.domain.tld or not?
In that case I don't know. If you send me the real hostname per pm I can have another look.
Otherwise I would suggest to send in a ticket.
