Solved How to update version DirectAdmin 1.62 to lasted version
Werachao
I can't use the ./build update command because of a download error. https://files-sg.directadmin.com/services/custombuild/2.0/custombuild.tar.gz doesn't work.
These old update files are not usable anymore for some time already.
It depends on how old your current version is. First try this if it's a very old one, as root via SSH:
./build update_versions
hopefully your DA version will get updated then at least.
After that, or if you are having a new version already, use this command from any directory:
da build update
da build update_versions
da build update
I've tried both methods but I get the following error and da build update the system says it can't find the command.
Do you have any other methods that work?
Try what it says in the error.
./build update_da
this should at least update Directadmin. After that you should be able to use the "da build update" and "da build update_versions" commands.
Be aware that some old PHP versions might not be available anymore on the new DA versions.
