Able to send the emails from webmail, but unable to receive
aaakhanc
I am using webmails as a part of my daily work. Since the morning today, I am facing the email bounce problem. All the emails which are being sent to [email protected] are bounced back stating the error "550 authentication required". I searched for a solution in forums but didn't get anything. Is there anyone who has faced the same problem in past? Will be ready to share more details, if any response received.
You might be on the wrong forums.
This forum is intended for support to Directadmin license holders, not hosting customers so if you are a hosting customer you should contact your host for support. Probably he changed something causing this to happen.
We can't see what's going on at that server or what is updated of whatever. Next to that probably some changes in root level need to be done, which can't be done by customers either.
So you should contact your host.
