subdomain management is broken for some reason (debian 11/12) DA version 1.672 > FIX Enable IPV6
mekmek
Netherlands
Hi @all,
I have (I think) some issue with Apache vhosts and subdomain management (looks like it has been broken since the upgrade from version 1.671 to 1.672 (not 100% sure it's related to this version, but could be). It's pointing to the default public_html default domain folder for some reason.
I did configure some test.mydomain.ext as test, but this is also pointing to the default placeholder with the Apache default text: 'webserver is functioning normally'. Strange thing here also is https (letsencrypt) is also pointing to the default domain on the server and it's not serving the test.domain.ext. When I do some checks at the certificate, the certificate has been configured with the test.domain.ext and it's valid.
apache2: config files looks like this:
/usr/local/directadmin/data/users/admin/httpd.conf
<VirtualHost IPV4IPhere:80 >
        ServerName test.domain.ext
        ServerAlias testje.domain.ext
        ServerAdmin [email protected]
        DocumentRoot "/home/admin/domains/test.domain.ext/public_html"
        ScriptAlias /cgi-bin/ "/home/admin/domains/test.domain.ext/public_html/cgi-bin/"
        UseCanonicalName OFF
        SetEnvIf X-Forwarded-Proto "https" HTTPS=on
        RewriteEngine On
        RewriteCond %{HTTPS} !=on
        RewriteCond %{HTTP:X-Forwarded-Proto} !https [NC]
        RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
        SuexecUserGroup admin admin
        CustomLog /var/log/httpd/domains/test.domain.ext.bytes bytes
        CustomLog /var/log/httpd/domains/test.domain.ext.log combined
        ErrorLog /var/log/httpd/domains/test.domain.ext.error.log
        <Directory "/home/admin/domains/test.domain.ext/public_html">
                <FilesMatch "\.(inc|php|phtml|phps)$">
                        <If "-f %{REQUEST_FILENAME}">
                                #ProxyErrorOverride on
                                <IfVersion > 2.4.59>
                                        ProxyFCGISetEnvIf "true" SCRIPT_FILENAME "%{unescape:%{SCRIPT_FILENAME}}"
                                </IfVersion>
                                AddHandler "proxy:unix:/usr/local/php82/sockets/admin.sock|fcgi://localhost" .inc>
                        </If>
                </FilesMatch>
                <FilesMatch "\.(php53|php54|php55|php56|php70|php71|php72|php73|php74|php80|php81|php82)$">
                        Order Allow,Deny
                        Deny from all
                </FilesMatch>
        </Directory>
</VirtualHost>
<VirtualHost IPV4IPhere:443 >
        RewriteEngine On
                                </IfVersion>
                        </If>
                </FilesMatch>
                        Order Allow,Deny
                        Deny from all
                </FilesMatch>
        </Directory>
</VirtualHost>
Known issue?, any tips/tricks what I could do to fix this.
Server version:
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
Directadmin version: 1.672 (DirectAdmin legacy)
All updates/upgrades has been done.
PS Is it save to downgrade to: version: 1.671 (stable channel) to check if this will solve my problem (not yet done some downgrades in the past)
Looks like I have now the Currecnt channel active which is serving version: 1.672 by default.
Many thanks+
Grtz,
Mek.
Hello Mek,
It most likely means, that your Apache's installation is broken. Probably there is an issue with syntax or missing module, anything else, that makes a syntax test to fail. When a new domain/subdomain is added, DirectAdmin tests a webserver syntax, and if everything is fine, then the webserver is either reloaded or restarted. Directadmin won't reload/restart the webserver if syntax test fails. And if you reboot the server, you will most likely find your Apache down.
If this is the case, you will need to connect as root over SSH and run the following command:
apachectl -t
It is expected to give simple Syntax OK with or without warnings. If it reports errors, you will need to fix them. Should you need any assistance with reported errors, we will need to see the full text (you might hide/fake domains and/or IP).
If no error is reported, then you might try and restart Apache manually. If it does not help, then you will need to make sure your subdomain resolves to a valid IP, which should be the same as in Apache's settings. It includes both IPv4 and IPv6.
Hi Alex,
Thanks for your response, would be appreciated.
Apache syntax looks like OK:
root@viper ~ # apachectl -t
Syntax OK
Manually restart Apache2 webserver will not solve the problem, also a system downgrade/upgrade will not solve this problem. So I decided to upgrade from Debian 11 to 12 ( to see if this wil fix my problem) afther this I did run a:
da build all
but without any success.
Both a and aaaa record for the subdomain are valid in (external dns, but also in the local named dns, which will not be used by the world.)
Everything where I browse to, will redirect me to: webserver is functioning normally .
Error logs are not indicating some wrong issues.
When I change my root directory to some other location. like: /home/admin/test with a .php test file or
index.html file, it's also not loading. So looks like I have to rebuild some services for Apache2. da build all is not
fixing my problem so far.
Any other things I could do to test or do I have to do a fresh reinstall.
Kind regards,
Mek.
Unless you have a completely wrong setup of Apache with custom files and templates, a full rebuild won't help. And if you try a full rebuild of Apache, I would suggest that you completely wipe Apache's configs and folders, checking custombuild/custom/ and templates/custom/ folders.
And still I think the rebuild is not necessary. Something is wrong with IPs which are Apache is bind to and/or interfaces.
What is the real domain name? May you send it in PM?
Your site opens over IPv4 fine, but fails to load over IPv6. That's the root cause.
Here is how can you fix it:
1. Connect to directadmin as admin
2. Go to "IP Manager" page
3. Add IPv6 on the page, if it's not added yet
4. Click your IPv4 on the page
5. Link IPv6 to IPv4 with the following options selected:
[v] Add to Apache
[v] Apply to existing domains
Give a minute or two and test your site.
Hi Alex,
Wow, thanks for your fix (it works now!). This did the trick indeed, good to know!
Many thanks for your help, is much appreciated.
Have a good day+
Grtz,
Mek
