Allow shell_exec on one (sub) domain
ericosman
Weert
Hi All,
Does anyone have an idea how i can allow shell_exec on one single domain / user?
I tried looking on the forum but could not find any way to allow it..
I believe it was already discussed here. You might check the results:
- https://www.google.com/search?q=individual+disable_functions+site:forum.directadmin.com
If to speak in general:
disable_functions can only be set once in the main php.ini file, and cannot be overridden by other areas, but this varies per php-mode. php-modes like php-fpm/fastcgi are much more stand-alone php instances, so you can get away with these types of overrides, away from the main php.ini.
- https://docs.directadmin.com/webservices/php/php-options.html
- https://docs.directadmin.com/webservices/php/secure-php.html#custombuild-secure-php
PHP-FPM,
For single domain, you can do something like this using "Custom HTTPD Configurations"
For Apache
ProxyFCGISetEnvIf "true" PHP_ADMIN_VALUE "memory_limit=256M"
For Nginx
fastcgi_param PHP_ADMIN_VALUE "memory_limit=256M";
I'm not sure, it's can or can't overwrite "disabled_functions" without remove from "php.ini", because normally php-fpm config can't overwrite disable_functions if it's exists.
In practice it would mean for PHP-FPM: remove disable functions from php.ini and add them in PHP-FPM.conf template file with a possibility to overwrite at admin level. I'm sure, I already posted more details about it on the forums. So it is a matter to find the thread only.
Well, i allowed shell_exec for all users, now the only thing is that i have to allow whois, dig and git in open_basedir somehow...
Does anyone know how i can add
/usr/bin/
To my openbase_dir? Because i cant use php whois, dig and git.
If you add /usr/bin/ into global open_basedir you will open all binaries in the folder for all users.
When I search I find this:
- https://docs.directadmin.com/webser...odify-the-open-basedir-setting-for-one-domain - probably not actual any more, as it describes a solution for Apache+mod_php. But it gives an overview on how one can customize things in Directadmin. The same can be done for PHP-FPM, but another routing in Directadmin interface should be used.
- This page https://docs.directadmin.com/webservices/php/php-fpm.html#per-user-php-ini-settings-in-php-fpm describes on how to customize things in PHP-FPM for individual users.
- This page https://docs.directadmin.com/webservices/php/php-options.html#php-options describes on how PHP things are managed and organised in DirectAdmin.
Existing docs will cover most of needs)
