issing Dropdown (domainnames) in ICON Grid Layout After Update
bcx
I’m using the ICON grid layout, and since a recent update, the dropdown menu in the top blue bar is no longer visible when in USER mode.
I manage multiple domains, and the dropdown made it quick and easy to switch between them. Without it, I now have to navigate through multiple extra steps, which is quite frustrating.
Is there a way to restore this feature? If not, could you consider bringing it back? It would greatly improve efficiency when managing domains.
Thanks in advance for your help!
Best,
Best,
Do you see that issue in DA version 1.673 or 1.672 ?
Please provide the screenshots from the recent version of DA you use and the previous one to see the difference and understand the problem better. because on my test DA I do not see anything wrong, but maybe I was just looking at the wrong place )
1.673 (d60afd28c44213338084fdc77fa3792c5ef7c7f7) is currently installed. I don’t keep screenshots of each version.
So, I assume this is a bug? Thank God, I thought it had been removed.
Let me know if you need any further refinements! 😊
attached a printscreen of the current install, red arrow points where normally the dropdown with all my domainname where listed.
The domains list is still available in all the user level-pages. It was moved inside the page (above the header on the right side of the page). With this change we are unifying the domain selector location on all the layouts (it was always in this place on the Refreshed layout).
The domain selector is not visible on the main dashboard because on the Icons Grid layout the dashboard is just a list all pages shown in a grid. Would you prefer showing it on the dashboard as well?
That location is not ideal and does not make sense, as the overview page already displays all domains. Kindly restore it to its original position in the blue bar. Having to navigate to the subdomain first is inconvenient, especially when managing multiple domains. (in the ICON GRID)
or
make an option in the settings page to activate this feature in the top bar, and maybe the possibilty to deactivate the search for pages, because that something i don't use. The Icon Grid is there for easy enough.
The domain selector is available in all the user level pages (except the dashboard), not just subdomains. I have used subdomains page just an example of "any page".
Thanks for the feedback. Indeed the location and visual style of domain selector could be improved. Our goal with the domain selector changes is to make sure we give users an option to select a domain in all the places where domain selection is relevant instead of making it global (like for example a language selector).
either one way, or another .. make the button / drop-down more prominent. endusers must see it. at the moment, they are used to the previous behaviour.
The previous setup was highly efficient, with the domain selection being globally accessible in the top bar on all pages. This allowed me to quickly select a client's domain name during a phone call, regardless of where I was in the interface. The new setup, however, requires unnecessary clicks and additional page loads to achieve the same result, making it less convenient.
As far as I’m aware, no one requested a change in its position—it was perfectly placed.
Is there a way for us to adjust this ourselves in the meantime with a code in a specific file? I use this feature daily, and the added steps have become quite frustrating.
Thanks for listing and hope you just restore it's postion asap. 🙏🙌🫶
Any ETA on that?
Custom plugin page doesn't have the dropdown which forces user to go to any other page with the dropdown to select the domain and only then come back to plugin page.
the missing domain dropdown is a pita, it concerns a big part of the settings, where on always must go back to domains and back to his settings. please bring the previous version back.
thank you, this is a blessing, i was so freaking mad each time i had to configure something in an other domain. Great job
