PHP CLI and FPM
Kurogane
I am having problems about the PHP INI configuration.
Currently it is using parameters in the FPM-POOL configuration.
To give an example, it has been configured to `memory_limit` overwrite the systemwide configuration which it does without problem.
What is the problem? when I try to run a script via CLI it does not use the FPM-POOL configuration if not the global PHP INI configuration.
How can I do to run a script via CLI respecting the FPM-POOL configuration?
Not working
I setup Per-path settings and setup memory_limit.
When i run /usr/local/php82/bin/php -i | grep memory_limit in the user. Always give me default PHP INI setting and not the one i set.
OK, I see. I was wrong, it won't work for PHP cli.
Currently, [PATH=] and [HOST=] sections only work under CGI/FastCGI.
See:
; Directives following the section heading [PATH=/www/mysite] only
; apply to PHP files in the /www/mysite directory.  Directives
; following the section heading [HOST=www.example.com] only apply to
; PHP files served from www.example.com.  Directives set in these
; special sections cannot be overridden by user-defined INI files or
; at runtime. Currently, [PATH=] and [HOST=] sections only work under
; CGI/FastCGI.
; http://php.net/ini.sections
Why do you need more RAM in a specific directory?
Not sure if understand correctly.
I want to use path settings because i think whatever php script run there overridden the setting.
For the other, is just an example and easy to detect if the configuration was working or not.
It turns out the PATH= does not work for PHP scripts in CLI. My question was on why do you need it? If you clarify your case, probably I could offer another solution.
Without knowing details I could offer to only start your scripts with:
#!/usr/local/bin/php -nc/home/username/php.ini
or with any other PHP path from your setup.
Impossible to make process CLI reading config from the fpm-pool.
just do simple thing.
php -d memory_limit=1G ./script.php
Because i say i use FPM-POOL.
In directadmin when you overriden the setting this going to php.conf and use php_admin_value and because is se there i wouldn't worry about the configurations.
I just want in user when use CLI not use global PHP INI if not use the setting of FPM-POOL or whatever it does not conflict with other configurations and use custom configuration.
Yes, I read this from so much searching before you posted and I see that a definite or temporary way, at least I want what I am looking for.
Currently, [PATH=] and [HOST=] sections only work under CGI/FastCGI. It does not work under CLI and FPM
