[WTA] Directadmin Pro Pack Features
alex2k
Behind You!
I have pro pack license but I can't find these features:
- WP Manager
- Node.js
How to enable for end user?
I'm using Ubuntu.
Thank you.
There is no pro pack anymore since several years, that pack was retired and included in the modern licenses.
So you have to check in your license if you have a modern (monthly paid) license then you should be able to find the WP manager in user level under advanced features.
If you have a lifetime license or personal (not plus) license then you do not have any pro pack features.
I was using lifetime license then switch to monthly license, but I still can't find WP Manager (see attachment).
How to enable it?
For nodejs, is there way to enable it also?
Thank you.
If a license you have includes these extensions, then make sure they are enabled in users' and packages' details. You might even untick them and save, then tick again and save.
What license that include those extensions?
I have standard license.
I don't use a modern license, but please check this post.
