Solved Clamav causing daily log floods with File path check failure on new server
Richard G
Maastricht
We installed a new server this week with clamav on it too (no uploadscan) and Maldetect.
Now in the logfiles we get a log file flooding like this:
Mar 14 03:09:26 server29 clamd[1464]: File path check failure on: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/srp_me.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure for: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/at.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure on: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/at.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure for: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/de_li.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure on: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/de_li.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure for: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/pt_pt.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure on: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/pt_pt.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure for: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/hu.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure on: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/hu.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure for: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/mk.gif
Mar 14 03:09:26 server29 clamd[1464]: File path check failure on: /home/customer/domains/customerdomain.nl/public_html/web/media/mod_languages/images/mk.gif
I can't find any "no permission" warnings, only the above.
Also checked the directory and the files do exist. For example:
-rw-r--r-- 1 customer customer  402 2025-03-04 20:13 mk.gif
-rw-r--r-- 1 customer customer  402 2025-03-04 20:13 mk_mk.gif
It's not only this customer, it's various customers when the check is done, causing log file floodings every night.
So since these files are present and reachable, what is causing this and how can I fix this?
ClamAV gets installed from an OS repository. DirectAdmin would need to fix the config file in such a case. Probably Directadmin developers are not aware of the issue, or have their own thoughts on the matter.
Ah yes indeed, that changed a couple of years ago.
I forgot that because normally I rsync the scan.conf and freshclam.conf from another server and then I don't encounter the problem. Probably forgotten this time. I'm getting old, LoL. :D
But well... fore sure somebody else will benefit from the solution on fresh installation some time in the future. ;)
Thanks guys, this happened to me too, started few days ago. I checked /etc/clamd.d/scan.conf and User was set to clamscan. Changed to root and problem solved!
