DirectAdmin 1.675
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.675.
This is a maintenance release, it has improvements for DNS related hooks, improves translation system (some messages were not translatable in earlier releases), updates the email limiting to correctly account for multi-recipient mails, and other smaller improvements.
DirectAdmin 1.675
A little problem ( not relate to this version, it's long time ago).
When update ImageMagick using "da build update_versions", something weird message show up, even same versions.
So I need to execute this command again.
This is a known issue (had a ticket with them about it in Sept 24), and they have fixing it on the roadmap. They said it requires a rewrite to some logic that is being done behind the scenes, so I guess it's not trivial.
Hello.
httpd: Syntax error on line 161 of /etc/httpd/conf/httpd.conf: Syntax error on line 3 of /etc/httpd/conf/extra/httpd-includes.conf: Syntax error on line 1 of /etc/httpd/conf/extra/mod_lsapi.conf: Cannot load /usr/lib/apache/mod_lsapi.so into server: /usr/lib/apache/mod_lsapi.so: undefined symbol: lscapi_set_criu_socket_path
Same as liblsapi-1:1.1-77
CloudLinux release 9.5.
Did you probably check this thread: https://forum.directadmin.com/threads/mod_lsapi-build-failed.72221/ it suggests the following solution: https://cloudlinux.zendesk.com/hc/e...d-lsapi-version-1-1-81-on-DirectAdmin-servers
Hello.
mod_lsapi-1.1-81.tar.gz was installed from the panel in CustomBuild, and after the httpd restart the specified error occurred.
Manual installation: "da build mod_lsapi, da build nginx_apache, da build rewrite_confs" did not help. mod_lsapi-1.1-81 is installed, but httpd does not start. Only the rollback to the previous version helps, mod_lsapi-1.1-73 with custom_versions.txt.
Don’t want to experiment yet on prod server, we will wait the next version.
Any fixes for the phpmyadmin issue where it won't open in mobile unless you have the popup blocker off in Google chrome on Android? Thanks. I appreciate your support.
A new version is released with the following changes is released:
  • Fixed Dovecot configuration when ssl_configuration=old is used in the CustomBuild options.conf.
  • Enable PHP ioncube loader extension compatibility with PHP 8.4.
Are da_interactive_custombuild didn't work anymore? just tried as usually - and it ignore this and install all by default
Yes. The installer variable DA_INTERACTIVE_CUSTOMBUILD is no longer used.
The installer already supported asking for License-Key interactively and CustomBuild had interactive configuration mode. To make installer simpler we have merged the two different flows into one. If installer is started without a license key it will enter interactive mode and will ask for both - license key and CB options.
I've identified an issue with the reload option in the Process Monitor.
For some reason, when clicking this option, the refresh interval choices no longer appear... in other words, nothing happens.
Tested with both Mozilla Firefox and Google Chrome browsers. The problem occurs in both DirectAdmin versions 1.674 and 1.675.
Are the links working correctly on the 1.675 Changelog page?
I'm seeing a lot of
(dns_write_post.sh hook)[/developer/hooks/dns.html#dns-create-post-sh]
Scattered throughout.
