named doesn't response
gate2vn
Oslo
On a Almalinux 9 server, the named service doesn't response on ipv4, but it answers on ipv6. CSF has been disabled, no other firewall.
The config is just like other servers
allow-transfer { none; };
listen-on port 53 { any; };
listen-on-v6 port 53 { any; };
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
memstatistics-file "/var/named/data/named_mem_stats.txt";
recursing-file "/var/named/data/named.recursing";
secroots-file "/var/named/data/named.secroots";
querylog yes;
allow-query { any; };
Error
dig @name-of-dns-server adomain-on-theserver
; <<>> DiG 9.10.6 <<>> @name-of-dns-server adomain-on-theserver
; (1 server found)
;; global options: +cmd
;; connection timed out; no servers could be reached
Any idea why? Thanks.
Bash:
# netstat -ntpl | grep 53
tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      47937/named
tcp        0      0 ipv4-of-theserver:53        0.0.0.0:*               LISTEN      47937/named
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      47937/named
tcp6       0      0 ipv6-of-theserver:53  :::*                    LISTEN      47937/named
tcp6       0      0 ::1:953                 :::*                    LISTEN      47937/named
tcp6       0      0 fe80::216:3eff:fe50::53 :::*                    LISTEN      47937/named
tcp6       0      0 ::1:53                  :::*                    LISTEN      47937/named
Bash:
# systemctl status named
● named.service - Berkeley Internet Name Domain (DNS)
     Loaded: loaded (/usr/lib/systemd/system/named.service; enabled; preset: disabled)
     Active: active (running) since Wed 2025-04-02 12:58:55 +07; 3h 16min ago
    Process: 47933 ExecStartPre=/bin/bash -c if [ ! "$DISABLE_ZONE_CHECKING" == "yes" ]; then /usr/sbin/named-checkconf -z "$NAMEDCONF"; >
    Process: 47936 ExecStart=/usr/sbin/named -u named -c ${NAMEDCONF} $OPTIONS (code=exited, status=0/SUCCESS)
    Process: 72490 ExecReload=/bin/sh -c if /usr/sbin/rndc null > /dev/null 2>&1; then /usr/sbin/rndc reload; else /bin/kill -HUP $MAINPI>
   Main PID: 47937 (named)
      Tasks: 10 (limit: 15546)
     Memory: 78.8M
        CPU: 4min 18.428s
     CGroup: /system.slice/named.service
             └─47937 /usr/sbin/named -u named -c /etc/named.conf
Apr 02 15:54:47 server-name systemd[1]: Reloaded Berkeley Internet Name Domain (DNS).
Apr 02 16:00:39 server-name systemd[1]: Reloading Berkeley Internet Name Domain (DNS)...
Apr 02 16:00:39 server-name sh[71411]: server reload successful
Apr 02 16:00:39 server-name systemd[1]: Reloaded Berkeley Internet Name Domain (DNS).
Apr 02 16:01:43 server-name systemd[1]: Reloading Berkeley Internet Name Domain (DNS)...
Apr 02 16:01:43 server-name sh[72387]: server reload successful
Apr 02 16:01:43 server-name systemd[1]: Reloaded Berkeley Internet Name Domain (DNS).
Apr 02 16:02:43 server-name systemd[1]: Reloading Berkeley Internet Name Domain (DNS)...
Apr 02 16:02:43 server-name sh[72495]: server reload successful
Apr 02 16:02:43 server-name systemd[1]: Reloaded Berkeley Internet Name Domain (DNS).
From this point everything looks fine. You might try and use tcpdump for a deeper inspection on a network level.
I found that if I request +tcp, it works. But by default with udp, it doesn't work. Checked with nc, can connect with udp/53
#nc -zvu server-ipv4 53
Connection to server-ipv4 53 port [udp/domain] succeeded!
Any thing else that I need to check?
Is resolving working correctly? Or nameservern name pushed correctly through DNS at the registrar? Did you check from outside (other server or home)?
I'm just wondering because of this:
this gave a timeout.
this (with ip) works. So I don't know if you tested with ip from external server too.
