Super Slow DA
Sickk1
Hey guys,
I tested a lot with Directadmin before i moved there.
Now I use it on my own server, with 5 websites and 1 small webshop.
I run also paperless ngx on it
Technical details :
KVM Server
10 vCores
16GB Ram
NVMe SSD
WP Limit 1GB
I run OLS
I need you help becuase it got so crazy slow that I would have to move back to a normal webhosting , as this was a lot faster.
eg christina-peter.de/shop
Has nothing to do with DA ! am afraid,
its more your VPS provider (Contabo?) check your "steal" values and monitor your server resources
Happy, that I can figure that out.
It's HostOn.
I have a steal of 0.0%, so that's not the issue.
I have Cloudflare upfront, maybe thats a problem ?
Yea, it's KVM not shared CPU.
Thats why I can't explain the problems I'm facing.
KVM is a type of virtualization and sometimes they advertise it as "guaranteed resources" because its KVM (OpenVZ works different as example) most of the time provider is simply sharing the Server(Hypervisor) his CPU among other VPS user on that server too (oversell).
Please monitor your sever resources with program like htop inside your server to be sure.
Did you check your TTFB ? did you execute an server speed test to determine your real connection speed ?
Interesting,
TTFB is on one domain good and on another one, same server, also Cloudflare, very bad...
I post the htop, when I load a website.
Ok, found out that the TTFB is just so slow on one website.
TTFB for php and mysql is superquick, so it must be the website ?
Is this php-fpm ? try increase "pm.max_children"
Since wordpress is the big framework, so default (10 children) might not enought.
I guest something have problem on backend... Like database,
Check in "Admin Tools -> DB Monitor", It's should show the list process when still in processing longer times.
The htop does not show IO/wait, you might use top as well. The top might show something like this:
Tasks:  95 total,   1 running,  94 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,  0.0 id,100.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   1971.0 total,    428.0 free,    255.5 used,   1287.5 buff/cache
MiB Swap:   1024.0 total,   1020.7 free,      3.3 used.   1549.9 avail Mem
where 100.0 wa while other parameters are 0.0
And 93% for lsphp isn't that too high for a small webshop? I believe bad coding and/or SQL queries might be an issue here.
